Mounting An A-series On An Engine Stand
#16
Posted 02 April 2020 - 01:38 AM
#17
Posted 03 April 2020 - 12:27 PM
Is there a reason people don't use the flywheel housing bolt holes?
#18
Posted 03 April 2020 - 01:23 PM
Probably because it's on aluminium so would break.Is there a reason people don't use the flywheel housing bolt holes?
#19
Posted 03 April 2020 - 05:37 PM
No, I meant where the flywheel housing bolts to the block.
#20
Posted 03 April 2020 - 05:43 PM
That's called the transfer case. I can't see why not on these holes ?
No, I meant where the flywheel housing bolts to the block.Probably because it's on aluminium so would break.Is there a reason people don't use the flywheel housing bolt holes?
#21
Posted 03 April 2020 - 06:24 PM
You might find the nose of the crank in the way... I´m pretty sure I´ve posted this picture before in other engine stand thread, but here´s how I did it. My stand came with moveable mounts I could align with the holes for alternator mounts and the oil filter mounts. I used some square section and heavy washers to space it all out make sure it mounted farily level.
edit: oil filter of course. brainfart.
Edited by InnoCooperExport, 05 April 2020 - 09:51 PM.
#22
Posted 05 April 2020 - 11:31 AM
That's called the transfer case. I can't see why not on these holes ?No, I meant where the flywheel housing bolts to the block.Probably because it's on aluminium so would break.Is there a reason people don't use the flywheel housing bolt holes?
Thanks! I see what you mean now! I wasn’t thinking straight!
Bing (1)
