Ball Joints Need Replacing
Posted 04 September 2009 - 11:17 AM
im in the process of replacing both ball joints on both sides. i was just wondering can this be done without taking the hub off. Also im not too sure how the torque pressure works can any 1 explain for me ?
Posted 04 September 2009 - 11:23 AM
What do you mean by not understanding the torque pressure? The torque is basically how tight the nuts etc need to be tighten up too. Best to buy a torque wrench like this - http://rover.ebay.co...9...d=824&kw=lg
You'll find you'll use it a lot more than just tightening nuts to the correct torque - because of the length, they make light work of undoing tight nuts!
Posted 04 September 2009 - 11:24 AM
Oh and forgot to say theres no need to take off the hub
Edited by jinjrich, 04 September 2009 - 11:25 AM.
Posted 04 September 2009 - 11:25 AM
You need to split the upper and lower ball joints, and remove from the arms if you're replacing both upper and lower ball joints.
By this time all left holding the hub on would be the brake caliper and steering arm, so remove these first and split both balljoints. Next reshim the top ball joint, and grease etc, then lift the lower pin out of the lower arm and you can rotate the hub and put the new top balljoint in the bottom arm, reshim the lower balljoint, turn it back over, and reconnect everything.
Saying that, removing the hub and doing it all on a bench is easier, and only one more bolt to undo.
Dave
Posted 04 September 2009 - 11:26 AM
But you shouldn't do this, as the shock loading you use can damage and alter the torque setting parts.
Instead spend £10 on a nice breaker bar that you can jump up and down on all you like.
Dave
Posted 04 September 2009 - 11:29 AM
Posted 04 September 2009 - 11:31 AM
thanks guys helps alot now i understand. this will be the first time i've changed ball joints but i need to learn as im going to do an apprentiship or mechanics soon but still 1 more question, when i order the new ball joints from minispares should i order a few different shims
You get some with the ball joints but i reckon its a good idea to get a few more. Just get a selection - if you dont use them all you can have them spare and use them when the joint wears a bit....
Posted 04 September 2009 - 11:38 AM
Posted 04 September 2009 - 11:47 AM
Posted 04 September 2009 - 12:10 PM
Posted 04 September 2009 - 12:17 PM
http://www.minispare...=...NT 1.5
splitter
http://www.minispare...=...&title=BALL JOINT SPLITTER SCISS...
although half the price from machinemart
http://www.machinema...l-joint-remover
oh and a torque wrench
Edited by lrostoke, 04 September 2009 - 12:18 PM.
Posted 04 September 2009 - 12:27 PM
Posted 04 September 2009 - 01:27 PM
I would always remove the hub and secure it in a vice - the existing joint can be hard to undo and torqueing the new ones is also difficult with the hub flapping about on the lower arm.
Removing the hub gives you chance to check the wheel bearings, seals, CV joint and gaiter. However you wmay need a torque wrench capable of 200lb/ft to reassemble (depending on the CV type) - I strongly recommend the biggest in the Halfords range.
Posted 24 September 2009 - 12:15 AM
Posted 24 September 2009 - 11:12 AM
Does anyone no where i can just buy shims as i used all the shims out of both balljoint kits to do one side, if anyone can point me in the right direction it would be a big help thanks fella's.
Cookie,
There's something wrong if you've had to use all the shims, did you remove all the grease and clean up the surfaces before rebuilding and filling with grease?
The ball joint pin should only just be movable by hand when done up tight, not free moving.
Dave
