Project Erm
834 replies to this topic
#91 mini_matt_106
mini_matt_106
  • 591 posts
Posted 24 February 2010 - 08:53 PM
tubing arches is more for wheel clearance so you can get a low low mini ;) and would get rid of your bodged section :wub:
#92 scsracing
scsracing
  • 276 posts
Posted 25 February 2010 - 04:40 PM
tubing arches is more for wheel clearance so you can get a low low mini ;) and would get rid of your bodged section ;)
Hmm still not sure though.Which part are you referring too as the bodged section though?
#93 scsracing
scsracing
  • 276 posts
Posted 25 February 2010 - 08:26 PM
Lookey what turned up today
and this
Likey likey only thing now is i need Dad to finish repairing the bulkhead, carefully remove the scuttle, remove the old inner wings and then prime and paint the panels before it can all be fitted to Erm. Still he's got another three weeks off work so hopefully most of it will be done by then. :-
#94 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 25 February 2010 - 08:36 PM
Be patient young one the force is strong in your father but not that strong :-
Anyway today i have mainly been doing this
and this
and this
and this
2 more bits to do then onto the big repairs under the cross member.
#95 mini_matt_106
mini_matt_106
  • 591 posts
Posted 25 February 2010 - 11:18 PM
tubing arches is more for wheel clearance so you can get a low low mini :kiss: and would get rid of your bodged section :w00t:
you said they had been messed about with? #head scratch#
basically the arch comes down a fair bit before reaching the outer body if that makes sence, when you tub the arches you take a straight piece of metal and go from that nice piece of metal you had (inner arch) and come straight out, if you search there should be a couple guides i'll have a quick look for you :wub:
#96 scsracing
scsracing
  • 276 posts
Posted 26 February 2010 - 07:21 PM
tubing arches is more for wheel clearance so you can get a low low mini :P and would get rid of your bodged section :lol:
basically the arch comes down a fair bit before reaching the outer body if that makes sence, when you tub the arches you take a straight piece of metal and go from that nice piece of metal you had (inner arch) and come straight out, if you search there should be a couple guides i'll have a quick look for you :tumble:
Yeah that bodge wasn't a bodge just were the outer arch had to be pulled back as it was much further forward than it should be so when the last guy replaced it he must of not had it in the right place.Don't think i will box the arches though,thanks for the suggestion but its just not for me at the moment :tumble:
#97 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 26 February 2010 - 07:58 PM
Last parts of the upper bulkhead done and rust treated, it will get a lick of etch primer tomorrow and then its on to the big sections of lower bulkhead to replace.
Oh the joys of mini welding!!! :tumble:
#98 jwb_moto
jwb_moto
  • 1,387 posts
  • Local Club: PMOC
Posted 26 February 2010 - 09:02 PM
when we did my mates inner wings we got the heritage ones with the A panels already attached. It really saves a lot of hassle linning panels up and takes the guess work out of it. |Your dad deffo has a lot of patience.
#99 scsracing
scsracing
  • 276 posts
Posted 26 February 2010 - 09:14 PM
I saw the inner wings with a panels already welded in but there was quite a difference in price to just buying them separate.Hopefully once all the inner wings are in and the front end is on then lining up all the wings and a panels plus scuttle shouldn't be too bad although when the wings arrived my dad spent some time getting them so they would just line up with the front end for the picture above.So the panels may need some adjusting they will fit in the end :tumble:
Yeah he does have alot of patience but its probably because he knows the end result will be good and he would rather spend time making sure i drive a safe car rather than some patchy old death trap held together with filler and waxoil :P .I feel so left out at the moment as i have never done bodywork on a car before so just let my dad do it as he has alot of experience in welding and metalwork.I will feel better once i can start to assemble parts and put them on the car.I would start to build up rear subframe but the powder coaters are alittle slow so my parts are gunna be a while yet :lol:.
#100 jayare
jayare
  • 2,093 posts
Posted 26 February 2010 - 09:21 PM
Have a practise welding some of the pile of bits you've cut off back together - once you get the hang of it it's not too difficult and I'm sure your dad would welcome the help!
JR
#101 scsracing
scsracing
  • 276 posts
Posted 26 February 2010 - 09:41 PM
JR
Have had a go at it a little while back,really do need to get some more practice in though.Problem is the only day in the week i get off is a Sunday and my dad works 4 on 4 off so rarely gets Sundays off.Although he has the next 3 or 4 Sundays off though so maybe have a go then.Think my plan for this sunday is remove rest of wiring loom and place in the bin(dad hates wiring,so i get to do instead although weirdly i like doing it :tumble: ) and strip the engine down some more plus whatever else needs doing(more than likely re-arranging the storage space for about the tenth time to try and squeeze some more parts in :P .Sure i can get some welding practice in though and have a go with the new helmet i got my dad for crimbo :lol:
#102 scsracing
scsracing
  • 276 posts
Posted 27 February 2010 - 04:40 PM
A bit more work carried out on the front bulkhead today.
Dad fabricated this new lower bulkhead panel and transferred over the heater box hooks and also a couple of welded in nuts,
Old rusty bulkhead section,
New section clamped in place after area rust treated and Zinc primer applied to bulkhead cutout and repair panel,
Internal view,
This will get spot welded in tomorrow and Dad will cutout and fabricate the remaining two sections of bulkhead while i get to play with the engine. Head off time to see what state the engine is in. First time for me with a proper engine although i used to build Nitro engines for model cars. :thumbsup:
#103 scsracing
scsracing
  • 276 posts
Posted 28 February 2010 - 05:41 PM
Well took the head off today and its not good news for the bottom half of the engine as all bores have quite a large ridge plus there appears to be a far bit of play in the pistons. :thumbsup:
On the plus side tho the head is good, all the valves are tidy with minimal wear in the valve guides,
Before
After
Also we finally got the corroded pot joint off but i had to grind it off then Dad gave it some large abuse with a hammer and chisel and it finally gave up
However i did learn that grinding can give you a bit of a hot spot especially around the crown jewels :(
Dad fabricated the r/h repair panel for the lower bulkhead and tacked it in place, just the l/h to do tomorrow
Edited by scsracing, 28 February 2010 - 05:42 PM.
#104 scsracing
scsracing
  • 276 posts
Posted 01 March 2010 - 07:31 PM
Well quite a bit done today, Dad finished fabricating the bulkhead repair panels and fitted them just the grinding left to do inside the car.
While he was waiting for primer and rust treatment to dry he whipped the scuttle off and look what he found
R/h side
L/h side
and the top edge of the scuttle was just bare metal, no treatment what so ever.
Somebody had gone to all the effort of replacing the scuttle but no preventative work done to any other of the areas covered by the scuttle. What a clown.
#105 guywithvan
guywithvan
  • 1,081 posts
  • Local Club: MedwayMiniClub
Posted 01 March 2010 - 08:26 PM
really impressed by your dads skill's here so far looks like some quality work gone into it ,your one lucky lad im sure this mini is gonna be a stunner when its finished,keep up the good work fella's your doing a great job of saving this one :dontgetit:
