Project Erm
840 replies to this topic
#511 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,079 posts
  • Name: Neil
Posted 17 March 2011 - 05:42 PM
Well i have to make a big apology to everybody who have followed this thread and used some of the information on it. I have had a major set back with paint reaction and its my fault so i will explain.
I have mentioned on numerous occasions that when i had been prepping joints for welding i had used primer and top coat then welded and followed by touching up with topcoat again. In a lot of places normally hidden out of sight this has not been a problem but on my door skins and some other joints there has been a massive paint reaction when the car has been sprayed in the paint booth.
This in turn has caused a lot of remedial work and a hefty increase in our paint bill which is not good at all. This my fault and i fully accept this so if anybody has suffered the same problem after following my info then all i can do is apologise.
Its been a kick in the teeth especially to Scott as he is funding the respray, i will not divulge how much its going to cost but it is considerably more than we bargained for so a lesson learned. The zinc rich primer is not the issue here but the top coat paint i bought from Halfords.
The painters are going to try a sealer to see if the reaction can be prevented on other parts of the shell but i will be going in tomorrow to strip those potential areas as a cost saving exercise.
On a positive note the doors bonnet and boot have come up really well so very pleased with the finish. Hopefully the shell will look the same but time will tell.
Neil
#512 vaughn1
vaughn1
  • 194 posts
Posted 17 March 2011 - 05:55 PM
its such a shame to hear this.
could you put up what exactly it was that reacted so others like me will not make the same mistake?
vaughn
#513 sonikk4
sonikk4
  • 16,079 posts
  • Name: Neil
Posted 17 March 2011 - 06:53 PM
vaughn
I will see if i can take a couple of pictures at the body shop tomorrow but no promises. Shifty had a reaction on one of his cars, its something similar but not quite as drastic. Its called pickling.
#514 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 17 March 2011 - 07:30 PM
Hi Neil
That is such a shame after the huge effort you put in. I feel so sorry for you. What is so admirable about you is that you confess to a supposed mistake but you had done your utmost to do it right and help all of us at the same time. You also don't let it stop you but deal with the fault and get on. I am the other way. And you were right Neil my windscreen didn't fit. I had a wee play with it on Tuesday night but was so disheartened I have left it since!
I'm certain that you will sort your paint problem - if anyone can it's you. Then as time passes the horrible and disappointing memories will fade!
All the best Neil
Hugh
#515 sonikk4
sonikk4
  • 16,079 posts
  • Name: Neil
Posted 17 March 2011 - 07:41 PM
Cheers Hugh :xmas: :xxx: we've gone so far with the car we cannot afford to let things like this stop us. It would be like taking a suitcase of money and setting fire to it.
It could be worse, i had to run a very small shift on sunday and jack a B747 twice to remedy a damaged under carriage door. We managed after much messing around and all was sorted, however the damn thing reappeared back at the hangar yesterday with the door damaged again and nobody can find the reason why. Sort of makes the Mini problem look very minor. Such is life.
#516 1964Woody
1964Woody
  • 201 posts
Posted 17 March 2011 - 07:47 PM
That really sucks. We have all followed this project with great awe and learned from each step you took. Now we will learn from this setback to be sure. I am now going to check with my paint suppliers to be certain that all the primers and undercoats I am using are compatible with the paint.
#517 sonikk4
sonikk4
  • 16,079 posts
  • Name: Neil
Posted 17 March 2011 - 07:55 PM
Having had a chat with the body shop guys it would appear that the two pack synthetic paint they are using does not like the acrylic paint we get from Halfrauds. Its only small amounts of painted areas but enough to cause the grief. They did tell me what the paint was called but for the life of me i cannot remember what it is, all i know is its a German paint.
I will remember this for the next project. They say you learn from your mistakes and i have to agree.
#518 Scholes2012
Scholes2012
  • 239 posts
  • Local Club: NONE
Posted 17 March 2011 - 08:17 PM
Those's Germans hey, trying to throw a spanner in the works, keep us posted.
#519 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 18 March 2011 - 08:26 AM
Shame you've had such a set back but at least we can all learn from this as well as your successes. I did a quick tart up job with acylic cans the other day on a mini roof & really struggled to get a half decent finish. Hope you get it sorted easily.
#520 sonikk4
sonikk4
  • 16,079 posts
  • Name: Neil
Posted 18 March 2011 - 07:14 PM
Spent the day at the body shop stripping off all remnants of the Halfords top coat that i had previously applied so 8 hours later it was all off. Next job tomorrow is to tape off the remaining areas that do not need fresh paint as its all hidden but it will get some fresh rattle can paint to protect it.
The doors, bonnet and boot have been painted and have come up really well although they will need another coat of paint to remove a few defects
In the meanwhile Scott has been busy building up the front subframe and has nearly finished it although things will need to be adjusted removed etc but it looks really good.
And the tops of the towers nice and smooth
And the towing eye
Still a bit of work to do on it but for a first time attempt i feel the boy has done good so at least things are looking up. >_<
#521 grahama
grahama
  • 2,442 posts
Posted 18 March 2011 - 07:40 PM
WOW, looking spectacular !! Paint problems aside, the finish is looking great and love the built up subby. Despite problems I am still referencing your build for guidance !!
Graham
#522 minimuk
minimuk
  • 1,946 posts
Posted 18 March 2011 - 07:46 PM
It is a shame and unfortunate thing to happen especially if you are on a roll, but I am sure you will get over it and thank you for the tip to all of us,.....Halfrauds and German paints have nout to do with classic mini's,......
Those doors, bonnet and boot look pakka, can't say anything about the subbies, just JELL.
Keep it going.
Edited by minimuk, 18 March 2011 - 07:47 PM.
#523 sonikk4
sonikk4
  • 16,079 posts
  • Name: Neil
Posted 18 March 2011 - 07:51 PM
Graham
Cheers for that Graham votes of confidence like that are appreciated. >_< I feel its always best to admit if you have made a bit of a mess up with info so at least those mistakes won't be duplicated by other forum members.
#524 analogue_radio
analogue_radio
  • 4,897 posts
Posted 18 March 2011 - 08:03 PM
Subframe looks the nuts, is that waxoyl thats been applied into the corners?
That paint on the doors, bonnet etc.. looks brilliant.
#525 sonikk4
sonikk4
  • 16,079 posts
  • Name: Neil
Posted 18 March 2011 - 08:08 PM
Yes its Waxoyl, trying to keep the dreaded grot away. We will be applying a little heat to make it flow for a smoother finish but not too much heat.
