Project Erm
834 replies to this topic
#436 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 23 January 2011 - 08:24 PM
How do you cut such delicate small holes like in that last repair?
Ha this could be a trade secret??? errr no i used one of these
right angle high speed grinder with a oval shaped grinding burr. I drilled a couple of 1/4" holes one each end of the area to cut out then using this wee beastie opened the holes up until i had ground out all of the rust. We use these a lot in the Aviation industry especially for corrosion removal.
#437 MiniLandy
MiniLandy
  • 796 posts
  • Local Club: HAMOC
Posted 29 January 2011 - 05:10 PM
Hello there mate, project's looking good!
Just wondering if you could cast your mind back to page two, where you reskinned the doors? I've just bought a pair of doors with reskinning in mind, and was wondering what skins you used, and were they any good, panel fit wise?
Cheers, Paul.
#438 custard
custard
  • 47 posts
  • Local Club: South Wales Mini Forum
Posted 29 January 2011 - 07:08 PM
After reading the whole thread twice, now have the motivation to continue with mine.... thanks for all the great pics and handy tips, they are worth there weight in Gold... cant wait to see it finished
#439 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 29 January 2011 - 09:59 PM
Cheers, Paul.
Hi with regards to the skins, i had bought a pair from Scparts fitted one but was not happy with the bow in the top of the panel once it was fitted so we went and bought Heritage skins. So much better and the overall fit was spot on. They are more expensive but worth it for the finish.
I did use the Scparts repair panels for the bottom of the door frame but again these were ok but i had to section these to straighten them out plus add corner pieces to make them fit properly.
#440 MiniLandy
MiniLandy
  • 796 posts
  • Local Club: HAMOC
Posted 30 January 2011 - 06:01 PM
Fair enough, i'll avoid the scparts panels then :)
Specifically though, what do you mean by the 'bow' in the top of the panel?
I'll be using pattern skins on my doors. I know the finish won't be as good, but then at a third of the price i don't expect it to be. I simply can't afford the heritage skins, so i'll be fettling some kind of pattern ones to get a decent fit. :)
#441 scsracing
scsracing
  • 276 posts
Posted 30 January 2011 - 06:07 PM
The 'bow' is at the top of the skin where the window goes through.At this point the pattern door skins we had tended to bow out meaning even with the seal fitted water would leak in.With the heritage panels we did not have the same problem although it might of just been bad luck for us and your pattern panels may be fine :)
#442 MiniLandy
MiniLandy
  • 796 posts
  • Local Club: HAMOC
Posted 30 January 2011 - 06:37 PM
Aah I see...
Thanks for sharing, i'll do a bit more research into different pattern panels, see where's best :)
#443 scsracing
scsracing
  • 276 posts
Posted 30 January 2011 - 06:47 PM
Well me and my Dad popped up to Bingley today.So glad we had a advance ticket as the queue for the other side was huge and we were second in so not out in the cold to long :) although I am sure to start with it was just as cold inside :) .Anyway I spent some money on a few bits.Got my first bargain which was the centre binnacle although i only needed the case and not the dials.
Went around a few of the shops and the auto jumble to pick up some other bits.The DSN classics shop was awesome and spent quite abit on some billet parts from them :) .Bit of a sucker for shiny stuff.
Smithys bits for more shinny stuff :)
Even though I had a list of stuff needed for both minis most of the shops didn't have everything I wanted but can pick up the left over stuff from the internet.
Alternators(standard and high power) for both minis plus a starter motor for erm
A mk1 grille from Minisport and some headlights for Paddy and Erm.
Then loads for nuts,bolts and washers plus some trim and small parts
Overall is was quite a productive day and saw some nice minis but it was extremely busy much more than last year or so it seemed :o
#444 Scholes2012
Scholes2012
  • 239 posts
  • Local Club: NONE
Posted 30 January 2011 - 09:55 PM
WOW your wallet must be a bit lighter now, I'll check back to see how you get on with the engine steady, mine didn't fit on the thermostat studs and I had to drill the hole nearest the radiator to 9mm. Nice lot of bit's though.
Edited by Scholes2012, 30 January 2011 - 09:55 PM.
#445 leaky
leaky
  • 6,890 posts
Posted 30 January 2011 - 11:27 PM
Holy crap. I thought I bought a load of bits. You've got a nice collection of parts their. How much was the center binnacle then?
#446 mhamps
mhamps
  • 91 posts
Posted 30 January 2011 - 11:30 PM
Nice new stuff you bought there!!
Matt
#447 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 31 January 2011 - 08:27 AM
Nice shopping trip. Good choice of components. I've either got or plan to get alot of the same parts. Let us know how you get on with the DSN engine steady. Keen to know if it's worth the pennies.
#448 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 31 January 2011 - 08:19 PM
£35 a proper bargain as others were wanting £70+, Scott only wanted the case so if anybody is interested in a low mileage speedo (this is supposed to be the true mileage as well) then pm me or Scott (scsracing)
#449 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 31 January 2011 - 08:33 PM
Will do,
Anyway back to Erm and his poor fitting Bonnet. This is really getting on my pip now it really is a poor fit so plan A was brought into action however it failed at the starting post
So with the gap like it is i thought i would slice the slam panel, move it up and then move things around, however it was a bad idea so had to weld it back up again and go to plan B.
This time i took a few measurements, offered up the new grill to see how things looked and decided to slice the bonnet edge to bring the lip down and then fill the gap with some new metal
You can see how much more metal needs to be added so i have got the filler piece rough cut so some final trimming and it will get tacked in but not until the weekend. Back on shift tomorrow so it won't get done till next weekend.
#450 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 06 February 2011 - 06:21 PM
Continued with the bonnet modding today
Filler piece welded in place
Ground down
It will need a little bit of hammer and dolly work but other than that quite happy with the gap.
Then it was onto the sides, original gaps
L/h side
R/h side
This was my fault when i fitted the wings, such is life so a lesson learnt
Anyway r/h side of bonnet cut and the new filler piece getting tacked in place
Just the front piece to do
In the mean time Scott has been busy sanding down Erm's backside back to bare metal
So hopefully by the end of play monday evening the bonnet will be finished so happy days
