Project Erm
834 replies to this topic
#391 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 25 November 2010 - 04:30 PM
Ye gods its cold in the garage so not a lot done but sorted some more of the stone chip reaction so tomorrow more coats will be added. However some bads news regarding the gearbox case. Its knackered BUGGER a previous owner used the wrong sized bolts to install the diff housing and cracked the case
Not happy campers so we do really need to get the flywheel off Erms old engine and hope that is not damaged. Oh well we have had enough setbacks so one more is not going to phase us. Mini's dont you just love them.
#392 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 25 November 2010 - 04:43 PM
Hi Neil, this project is amazing to see, such a shame about the gearbox casing but, could be worse i suppose, keep up all the hard work.
Dan..
#393 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 25 November 2010 - 04:50 PM
Cheers Dan really hacked off about the gearbox as we will have changed everything in it now including the case. Oh well such is life. How are you getting on with your beastie??
#394 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 25 November 2010 - 11:26 PM
its coming on. shame about the casing but the project still looking good, love the progress again. :blink:
#395 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 26 November 2010 - 09:57 PM
:- not to bad thanks, your thread gives me alot of motivation :D
#396 deemo
deemo
  • 185 posts
  • Local Club: LCMOC
Posted 27 November 2010 - 12:16 PM
Things have moved along since I last checked up here. It's coming on nicely!
Really wish I had read a project like this before I started mine, so much good advice.
Bloody hell, the gbox is properly fubared... :-
#397 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 27 November 2010 - 05:05 PM
Finally sorted all of the stone chip reaction and have now primed and top coated the underside of the car, part way done
all of the floor and rear arches and boot floor
Happy with it so far but a few more coats of paint needed then its onto the front arches, in the meanwhile i have also injected waxoyl into the right hand sill so hopefully no more rot to worry about there.
I will do the front inners next week along with stone chipping the front valance then i can take Erm off the spit to do the last of the bits and pieces prior to prepping for paint.
#398 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 03 December 2010 - 07:07 PM
Glutton for punishment in this temperature but the show must go on as somebody said.
Front inner wings got their shiny new coats today although they will need another coat tomorrow
L/h inner
R/h inner
Had another go at the flywheel removal saga but still no joy. Large hammer used no joy, large hammer and heat no joy so more heat to be used and more whacking followed by a large dose of leaving it alone. If this does not work then i will have to spend some more money and buy a heavy duty puller.
#399 minim@t
minim@t
  • 300 posts
Posted 03 December 2010 - 07:19 PM
Where abouts are you whacking with a hammer,
try a drift at 90degrees to the shaft and give the sleeve a good belt the shock should move it as long as theres a puller on adding pressure,
they can be buggers to get off
#400 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 03 December 2010 - 08:02 PM
Not tried that so will give it ago tomorrow thanks.
#401 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 03 December 2010 - 08:05 PM
looking brilliant neil :)
#402 prometheus
prometheus
    Starting My Mini Up
  • 3 posts
Posted 03 December 2010 - 08:35 PM
loverly work there fella :)
#403 grahama
grahama
  • 2,442 posts
Posted 03 December 2010 - 11:30 PM
have to agree, great work fella, keep it up
#404 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 04 December 2010 - 08:04 PM
Well didn't play with Erm today but had a go at Paddy's non working heater fan. For once it turns out to be a quick fix the switch is knackered so happy days. Still i dropped the heater just to be sure and found a pinched wire and one burnt through so replaced both of those. Also a huge amount of dust and loads of extra wires going to nowhere so they will be removed next week.
Oh and some hidden rust which for the moment will be left as i am not ready to mess around with A panels. We will make the most of his years MOT and then it will all get sorted out Erm stylee. :P
#405 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 11 December 2010 - 03:45 PM
Just a small update as only just got back from work (a long week) one of the lads at work works at the local a/c museum at the end of the runway at Gatwick so has access to these little puppies
Need a few more of different ratings then once the loom goes in these will replace all of the inline fuses and fuse box and be mounted in the car rally style. Not many cars can say they have bits of Mr Boeings finest airplane (B747) incorporated into them.
