Project Erm
834 replies to this topic
#286 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 08 October 2010 - 05:00 PM
Having a mate who is a mini fanatic is always a godsend so while at work it was a good time to check out the gearbox and glad we did too.
Fully stripped it to bare bones and found all sorts of nasties. One main shaft bearing totally shot Bugger, layshaft kaput due to bearings being shot. And the laygear are knackered as well due to the bearing damage, all caused by not changing the oil regularly. Oh also forgot about a knackered bearing on the differential as well.
Baulk rings are worn as well plus the input shaft lug was loose so the potential for very poor gear changes were high.
The main gears are good so apart from changing the bearings not a problem so its time for a full rebuild kit plus Laygears and so on plus welding the lug on the selector shaft.
We will rebuild it next month, i have another gearbox that we will strip as well to see if there is any goodies in there that we can utilize. Oh and make a centre oil pick up pipe.
Meanwhile its back to the bodywork and welding, oh the joys.
#287 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 08 October 2010 - 06:48 PM
Doing a really good job here guys, keep it up :proud:
#288 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 08 October 2010 - 06:51 PM
Doing a really good job here guys, keep it up :)
Thankyou :proud:
#289 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 09 October 2010 - 02:27 PM
Few piccies of the gearbox gubbins,
Knackered layshaft and bearings
close up of wear
Differential with knackered large bearing
Empty casing
Had another look at the main gearset and found a chip out of the fourth gear cog. Bugger!! But on the bright side my mate has just offered Scott a complete gearset including laygears and shaft plus some other bits for a case of wife beater and a bottle of red. Happy days as they are all in excellent condition plus a brand spanking new set of straight cut drop gears for not a lot of monies. Oh and Mr Dodd has given some very good info on the best set up for Erm and his running gear. :) :o
Due to bathroom woes no work done on Erm but he will get a jolly good work out tommorow. :o
#290 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 11 October 2010 - 06:58 PM
Finally got the l/h door skin fitted but a bit of prep work first
Inside the door frame primed and painted
Then on with the skin
Then onto the gaps
and then some gap filling
A lot more to do to get it just right but it will be worth it.
#291 daveeeeee
daveeeeee
  • 684 posts
Posted 11 October 2010 - 07:39 PM
So do you just use a super thin disc on a dremel or something and take a slot out?
#292 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 11 October 2010 - 08:01 PM
Nope i use some welding filler rods of various thickness, the one i'm using at the moment is 3.4mm thick. I will add another one and grind it down to get the gap right.
The same for the A panel gap as well everything else will be panel beaten as required
#293 RS##BAM
RS##BAM
  • 36 posts
Posted 11 October 2010 - 08:58 PM
just got through all this thread half this morning and the other half tonight . well worth the read lads, given me loads of hints n tips while doing mine . will follow with intrest so keep posting for us .
nice work going on to
Bam.
#294 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 12 October 2010 - 04:46 PM
Continued with the door gapping today, decided that the rear quarter panel needed to be sectioned so marked it out
Cut, closed up and spot welded.
Finished result, just needs some final filling ready for paint.
Completed the top corner
and overall finish
Then it was onto the front, yesterday the front lower corner bowed in slightly so after some light abuse with a panel beating hammer and block it ended up like this,
The A panel isn't quite right as its not folded round yet but it was later and the profile is good.
Now for the front gap. filler strip tacked in place and extra weld on the lower filler piece
Inside of the door filled with weld (lots of small tacks)
and ground down and polished up
More door antics to follow tomorrow >_<
#295 mini670
mini670
  • 293 posts
Posted 12 October 2010 - 05:39 PM
Looking Ace!!!
#296 daveeeeee
daveeeeee
  • 684 posts
Posted 12 October 2010 - 06:14 PM
Does that not mean you end up with a lip on the front of the rear quarter? Not complaining looks mint, just interested!
#297 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 12 October 2010 - 06:44 PM
No not at all, what i have done is effectively shortened the rear quarter by just over 1.5mm in that area by cutting a slot in it then compressing it so the edges touch again.
Also some very light hammer work with a panel beating hammer (i mean light as well) I have also used this process in several other areas to either shorten panels or slim them down.
It then looks like the original panel no lips, bulges etc just needs a thin skim of filler to finish off.
#298 daveeeeee
daveeeeee
  • 684 posts
Posted 12 October 2010 - 06:56 PM
So you've added to the door with filler rod in places, and taken from the a panel/rear quarter with slots and compression? =) Sorry for being a mug
#299 robbie9999
robbie9999
    Starting My Mini Up
  • 2 posts
Posted 12 October 2010 - 07:02 PM
do you still have the wheels for sale ? is there a number I can contact you on ?
Rob
[email protected]
#300 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 12 October 2010 - 07:04 PM
Yes that's right, bang on. >_< :xxx: addition and removal of metal the only proper way to get decent gaps. With the best will in the world Project Erm has fought me tooth and nail so far and virtually every panel i have fitted has had some form of additional work to make them fit well.
The final panel that will need more metal adding will be the brand new bonnet as the wing gaps are large. This is down to me unfortunately when i fitted the wings, i should have pushed them in harder to lessen the gaps but i thought i was going to damage the wings so a lesson learnt there.
