Project Erm
#16
Posted 13 September 2009 - 06:12 PM
#17
Posted 13 September 2009 - 06:25 PM
Those centers are cool
Nice aren't they.Those and the black wheels came to £82
Corr bit of a bodge job from the previous owner, nice to see it's being taken care of
Bodge job is not the word,its a mess.Mean just look at this 'washer'
Blue tack and a bracket
Edited by scsracing, 18 June 2011 - 07:45 PM.
#18
Posted 13 September 2009 - 06:49 PM
#19
Posted 13 September 2009 - 07:00 PM
I'm lead to believe that's standard! unless the same bloke bodged my mini as well
albeit mine had a lot less 'blue tack' and it was tidier.
Maybe we have a rare part only on 'special' minis,haha.Worth a fortune
#20
Posted 18 September 2009 - 09:59 PM
Replace both inner sills,
Replace both outer sills,
Replace both front floor panels,
Replace r/h door step,
Replace r/h 'A' panel,
Replace inner wing radiator panel,
Replace both door skins,
Repair bottom of l/h door frame,
Replace battery box,
Replace both rear inner arches,
Replace bodged/dodgy repair sections in boot.
There maybe more rust removal but it will be localised areas.
My dad will be replacing the door step this weekend plus removing the 'A' panel and starting on the sills.
He has already etch primed and sprayed black the door skins inner sides.
He has also sprayed the Supalites Silver/steel and clear coated them. Much much better than when we first got them with the car but still not perfect but will look good on someone else's mini. Will post more photo's tomorrow.
#21
Posted 19 September 2009 - 03:51 AM
#22
Posted 19 September 2009 - 09:32 AM
Nice Center caps, do mind me asking where did you get them from.
Hi
They were custom made,i may be selling them but i am not sure yet as i haven't decided.
#23
Posted 19 September 2009 - 12:23 PM
Keep it coming.
Edited by Mini-Mad-Craig, 19 September 2009 - 12:24 PM.
#24
Posted 19 September 2009 - 06:47 PM
The old outer seal,was a home brew job
Anyone missing any rust?i think it is here
New sill welded in
And a home made bit of the centre beam
Also wheels are done now,will be ebaying but if anyone wants them £150
#25
Posted 19 September 2009 - 07:39 PM
tasty wheels to!
L
#26
Posted 20 September 2009 - 03:04 PM
Ha any one spot the cheeky spider
#27
Posted 06 October 2009 - 06:16 PM
Started off my cleaning up some bits and bobs to take to powder coaters for a quote,had to clean up the sub which took a day.Loads of waxoil on it and had to clean up some corrosion on it too.
Some new tools came in the post
These drums look the same but honestly one is manky as hell but the photo doesn't show it.Only did one radius arm and one drum just to get a quote on powder coat.
Now for the bits my dad has done so far since he has been off
Old inner sill out but as we were waiting for a new floor pan
How many layers?
The rear inner sill cut out
My dad had to weld in the seat belt mounting point as the new inner didn't have one, Didn't tidy the weld up as its hidden in the empty space between inner and outer sills so it was just primed and sprayed black so that ti is protected.
New rear inner sill welded in (Has been primed)
Old outer sill removed,The sub mount has gone so it will probably be a new heelboard
Foot ventilation sorted out,not having a engine any more,going flintstones style.
Could probably survive going over a land mine with this old floor panel
Panel tacked in
Seam welded and ground down
The grooves don't line up which is really weird and the slots don't line up on the sills either??
#28
Posted 08 October 2009 - 05:56 PM
More panels required now are as follows:
Both door bottoms will need repair sections fitted as both bottoms are rotten,
Decided to fit proper replacement jacking points to both sides,
The heel board needs to be replaced at both sides which includes the subframe internal mounting brackets.
Will now have to fit larger sills due to the cutouts on the inner sills and replacement floor panels not lining up but will cut in breather holes like the original sills should have.
The right hand wing will have to go, its starting to bubble plus more welding required around the vent cutout and under the scuttle end.
The left hand one might go the same way but not just yet.
After being told that all the rust had been cut out prior to new sections being welded in it goes to show what a load of rubbish the previous owner was spouting.
If it wasn't for the fact that most of the outer shell is good then it would be cheaper to source another shell but in the end the car will be bullet proof plus a lot lighter.
Still at least my Dad's welder is going strong but he's bought two grinders so one is fitted with a cutting disc and the other a grinding disc. (B&Q specials)
#29
Posted 08 October 2009 - 08:05 PM
I know that feeling, so keep going fellas!
I love the inch thick floor pan. The poor engine must have been working hard to shift that weight...
#30
Posted 16 October 2009 - 07:10 PM
Some more rust
Started to clean it up
New door bottom fitted
Dad had to fabricate the corner sections so he could continue to do the door.
Door skinned
And after the paint reacted the first time the second time it was fine.Just got to waxoil the inside of the skin even though its primed and paint too(trying to keep the rust away)
Some bits sprayed up,the heater and one seat stop thing as it was just off at the time
Tidied up the bench so that it can be used now
Just want to get all my parts back from the powder coaters and backplates that i bought off here turn up so that i can rebuild the rear subframe.
Also thinking of getting a complete boot floor now as the old one is utterly terrible,patches are held on with filler and silicone and there is so much filler in there its crazy.whole boot floor is about £120 without battery box which i already have so it may be worth it as most of it is going to have to be chopped out.
My dad did attempt to replace the rear front subframe mounts but the panel we bought is terrible so i have got a complete rear heelboard but need to work out a price for it yet as i have;nt payed for it yet
Edited by scsracing, 21 October 2009 - 06:13 PM.
