Project Erm
834 replies to this topic
#196 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 14 July 2010 - 04:34 PM
looking good mate :lol:
#197 Mini-Mad-Craig
Posted 14 July 2010 - 05:14 PM
Looking very good! :lol:
#198 Hekmat
Hekmat
  • 246 posts
Posted 14 July 2010 - 05:35 PM
Looking great, at this rate you are going to finish well before me.
#199 vaughn1
vaughn1
  • 194 posts
Posted 14 July 2010 - 05:54 PM
fantastic work guys, cant remember how many times i have read right through this for inspiration.
are you using a spray gun to apply your paint at the minute or is is all done with rattle cans?
look forward to more updates.
#200 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 14 July 2010 - 07:58 PM
Mmm i think not, i am having trouble with the doors at the moment, the lower repair section i used curved the lower skin far too much so when i fitted the door frame into the cutout it looked poo, really bad gaps as well so working on those with shims etc before i fit the skin. The remaining bad gaps will be filled by welding welding rods for TIG welders on the door skin edges so the gaps will be spot on.
Cheers for the comments, rattle cans are the weapons of choice at the moment as its all hidden. The primer has still been flatted first before top coat on the rear quarters as this could be seen. Not too bothered about the door skin inner surface though but i thrown a lot of paint onto it. Once fitted it will be pumped with Waxoyl again.
Bloody new compressor turned its toes up today by blowing out a piece of the pressure controller body (either poor casting or somebody over tightened the union.) Its been sent back for repair or replacement so old faithful will be brought back into play.
Edited by sonikk4, 15 July 2010 - 03:21 PM.
#201 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 15 July 2010 - 03:25 PM
This is what was occurring yesterday, the door frame in the cutout getting shimmed up. Its still not right so will fit more shims next off shift.
Fettled and sectioned repair to the bottom of the door frame.
#202 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 21 July 2010 - 07:11 PM
Re-skinned the r/h door today and very pleased with the result
Not too happy with some of the gaps though, everything at the front lines up remarkably well but the back is cack so will need to use some welding filler rods to fill the gaps.
Also had to fettle the hinges as well as they would not fully open once fitted to the door
Once i replace the r/h rear quarter hopefully i can sort out the rear lower gap somewhat although some additional welding will be needed. Some more pondering time will be needed to come up with the final solution for the window frame gap.
#203 vaughn1
vaughn1
  • 194 posts
Posted 22 July 2010 - 06:41 PM
what was the problem you had with the hinges and how did you fix it?
#204 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 22 July 2010 - 06:44 PM
Busy day today, chopped out the old rear quarter
Found more rust covered by the recently fitted quarter by the previous owner
New quarter pinned in place
Started to reduce the large panel gap
With a bit more levering and hammer work i might be able to reduce it even more, i will need to chop around the quarter panel a bit more to get it to clear the bottom of the door radius.
Edited by sonikk4, 22 July 2010 - 06:49 PM.
#205 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 22 July 2010 - 08:26 PM
Sorry missed your question, basically the upper after market hinges Scott bought fouled on the edge of the door which did not let the door open fully. By chamfering the edge allowed the correct clearance and the door to open fully.
This may have had something to do with the new door skin but the skin was a really good fit so probably not.
#206 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 23 July 2010 - 06:19 AM
Looks quality, what tires are they?
Hi the tyres are Falken FK-07E's size 165/70 R10's and they have gone on 6 x 10 Minator rims. ;D
im running the same wheels and tyre's :) they grip very nicely to the road :]
and was your door steps Herriage ones or not?
thanks stevee
#207 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 23 July 2010 - 06:39 PM
The door steps were as follows, on the right hand side a mixture of Scparts door step and hand made by me and the full l/h side was made by myself.
Every one i had bought needed to be cut about to make them fit so after failing to get them right i made my own. As an Aircraft engineer i do sheet metal repairs so i made my own up including the l/h inner sill.
Never thought about the Heritage steps but as my son is buying all the panels then it does get expensive so making them was a cheaper option.
#208 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 23 July 2010 - 07:40 PM
Back to the door gaps again today, the lower rear corner of the door cutout got sectioned
and i then did a similar thing to our brand new Heritage quarter (bugger) and now the gap is much better
The gap still runs out going up so more material will be need to be welded to even it up.
Noticed one of the subframe bolts is at an angle so the captive nut had to come off and be repositioned but did notice whoever welded it on at the factory had fitted the nut too high so the bolt was catching on the edge or the hole. So much for trying bolts in the holes before selling it.
#209 vaughn1
vaughn1
  • 194 posts
Posted 23 July 2010 - 08:11 PM
impressive work, shame about having to fettle the heritage parts mind...you have a great attention to detail.
on another note, do you have any more pics of the way the sill fits with the heelboard and the front flitch? or any advice on fitting? as i am coming to that stage with mine. pm if you like.
vaughn
#210 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 23 July 2010 - 08:56 PM
vaughn
Are you on about the outer sill or the inner?? for the inner sill at the heelboard end the inner sill fits inside the heelboard flange and you can either spot weld it or seam weld. At the other end it is shaped to follow the contour of the flitch and this i spot welded although you can seam weld if you want.
The outer sill is straight forward but depending on what manufacturer you get them from. If they are Heritage then they come with drains holes in each end so its up to you whether you leave them or weld them up. Other companies sills don't come with them so no problem there. I would advise you to weld up the jacking point if you are not going to use them. (you can see where i filled it in the photo)
The heelboard end i personally cut the sill flush with the heelboard flange and seam weld, the other end i spot weld to the flange of the flitch panel and then spot weld the rest of the sill.
Flitch panel end
Sill fitted.
Hope this helps
Edited by sonikk4, 23 July 2010 - 08:59 PM.
