Hi
Well we got my 87 mini mayfair on saturday. Didn't look quite as good as it did on the advert but i don't mind.Striped it all down today to see what exactly is needed.
DAY ONE;
On its axle stands now to see what's underneath and to sell the 13x7 superlites as we're going for the standard arches .
Some very poor painting touch ups done around the doors and bonnet
Butchered arches after the last owner trying to fit the 13" wheels,got to weld on some new lips
Some ugly Ariel mount that will be going
The car has been sitting for a while so its all abit rusty and corroded but we plan on wire brushing the callipers then priming them and a coat of red.
Rear drums need there backplates replacing
Headlining needs replacing
The very ugly home-made dash that is extremely bad,this will be going straight in the bin
Badly done window tint is also to be removed along with the sprayed standard inside door handles
A mess
Roof vinyl will also be removed as it looks shocking up close
Goodbye to the indicator covers and blue tinted fog lights
Think it needs a clean,also alternator belt is covered in some sticky scum
Close up of bad front arch
Interior which is too be completely gutted and replaced
Project Erm
Posted 30 August 2009 - 06:17 PM
Posted 30 August 2009 - 06:29 PM
Stripping down time(for the car)
Alternator removed with radiator for clean up and paint
Interior out ,all looks good at the rear end bar some bad welds,handbrake cable snapped too
Heater matrix has been leaking so the front floor pan is corroded and needs to be replaced,centre console is a mess too,rev counter is at the bottom
Boot looks ok bar some bad welds again
Radiator cover and alternator spindle sprayed now and since have been sprayed red.
Some new interior door handles i got for £20
Got a new dash off of ebay(bargin),has all the dials for £68
http://cgi.ebay.co.u...IT#ht_500wt_975
And going to order some new bits now too
And heres the superlites i am selling for £200 if anyone is interested
Also got two better chrome bumpers for £15 and a new grill for £10.Also going to pick up a half leather interior next weekend for £75
Edited by scsracing, 30 August 2009 - 06:40 PM.
Posted 30 August 2009 - 06:32 PM
Hopefully it will be a bit more tasteful than before
Good luck.
Posted 30 August 2009 - 06:42 PM
Nice to see an overhaul like this
Hopefully it will be a bit more tasteful than before.
Good luck.
Thanks,should turn out alot better than what it was,got over 7 months to do it in
Will post soon with a do to list(hope it stays the same length,haha)
Posted 30 August 2009 - 06:52 PM
Interior
Replace interior
Replace dashboard
Replace heater matrix
Remove tinted cover off rear windows
Relocate speakers to floor level
Remove center console and replace
Engine
Alternator squealing
Steam clean engine
Fit air filter housing
Refit dizzy splash guard
Service engine
Replace heater valve
Replace engine mounts
Replace front subframe mounts
Replace water pump
Replace stat housing
Replace upper rad hose
Replace lower rad hose
Replace bypass hose
Replace various hose clips
Replace stat gasket
Replace water pump gasket
Exterior
Adjust headlights
Sort indicators
Remove fog lights
Sort brake lights
Remove roof decals
Replace wheel arch spats
Replace wheels
Replace handbreak cable/s
Sort ariel mount on roof
Panels
Adjust headlights
Sort indicators
Remove fog lights
Sort brake lights
Remove roof decals
Replace wheels
Suspension
Tiebar mounting rubbers
Posted 30 August 2009 - 06:56 PM
I like other people's to-do lists!
Posted 30 August 2009 - 06:59 PM
Mmmm this is going to be good.
The main work should be done at the weekends but the smaller jobs will be done on weekday evenings.Hoping to make that to do lists smalled and not bigger too
Posted 31 August 2009 - 07:32 PM
Also picked up my new seats,there the ones out of the mini 30.While i was there i got a rocker cover for £10
Dash out
The dash once i was finished with it.
Red radiator cap
Rocker cover i got for £10
Posted 06 September 2009 - 05:49 PM
All the fuel pipes,brake pipes are shot and the handbrake cable is snapped.
Subframe out
bit of worked needed underneath
Some very untidy welding done by the old owner
My new dash
And the superlites are now being refurb as they where very bad,just done the edge so far,the centre should be getting bead blasted this week
Scs
Posted 06 September 2009 - 05:56 PM
Posted 06 September 2009 - 06:27 PM
Posted 06 September 2009 - 07:19 PM
Posted 06 September 2009 - 07:28 PM
Lucky it will be going for a re spray so we can get busy with the grinder and filler,should hopefully be ripping into the rear subframe soon and sorting it out,the arms need new bearings/bushes and we need to clean it all up and replace some bits,then just a lick of paint on the sub frame.Engine will be coming out soon too for a rebuild.
God knows how it ran as when we was taking the tank out today the fuel line wasn't even connected to the carb
Need to stock up on etch primer,hammerite,more vw red paint and some more wire brushes for the angle grinder as the ones for the windy are more expensive and harder to get hold of.
Also that glue for the window tint is a pain to get off,we tried hot water and soap, mentholated spirits,paint thinners and finally had to use nitromoors
Anyway back to running round the net looking for my next fix of parts
Edited by scsracing, 06 September 2009 - 07:30 PM.
Posted 13 September 2009 - 05:13 PM
mainly more stripping and cleaning today.
Cleaned off waxoil today on the rear subframe with some nitro mores as i planned on getting the subframes powder coated.They will be chemically cleaned and blasted but thought i would take off the waxoil
Still busy refurbing superlites ready to sell.first layer of primer
Now for the shiny bits
Got this steering rack bracket for lowering the rack,not mine but will hopefully be getting on some.Its a monster and much better than the other ones you can by,made from stainless steel and solid.
Some black mistral wheels(minilites)They have been powder coated.
And some awesome centres for them.Made from stainless steel and should last longer than plastic ones
Also can someone tell me if that dash i brought which is in one of the posts above is from retrodash,i think it is.
Edited by scsracing, 13 September 2009 - 05:14 PM.
Posted 13 September 2009 - 05:48 PM
