looking superb - detail on the door shut is excellent
had to do this on Ratty, had to add some 10g strips...
Posted 27 October 2009 - 08:49 PM
Posted 27 October 2009 - 08:52 PM
Posted 27 October 2009 - 09:01 PM
I got away with welding up the edges, to be honest the door skin fit was actually pretty good, quite impressed.
(I wonder if I'll ever get the chance to compare the fit of a pattern door skin to a genuine one???)
I did get a bit carried away and *rec of the tum* with the door gaps![]()
Posted 27 October 2009 - 09:22 PM
Posted 27 October 2009 - 09:54 PM
James' hasn't got any worries with his sprite !! It's in good hands..
Posted 28 October 2009 - 08:59 PM
Posted 29 October 2009 - 07:25 AM
Right well, I've been busy(again!!)
Dots WILL be going to Roofless for paint this weekend so I've been pulling my finger out!!
So.......
Played with passengers side door to get the gaps spot on
Had to go a bit of welding and grinding but the results were worth it!!
There was a little rust hole in the roof..
Which I promptly turned into a BIGGER hole!!!
And then welded up and ground down!!
Pleased with that as well, bit of a filler skim and you won't know its there!!
I've also welded up the other speaker hole, and started to prepare it for priming.
By the weekend it will have
- Etch prime
- Bar coat
- 2 coats High build primer.
Then its just a quick seam seal and Roofless can have it!!
Watch this space!!
Posted 29 October 2009 - 09:25 PM
Posted 29 October 2009 - 09:34 PM
Posted 29 October 2009 - 09:54 PM
Posted 29 October 2009 - 09:59 PM
Posted 29 October 2009 - 10:01 PM
Posted 29 October 2009 - 10:03 PM
Posted 29 October 2009 - 10:04 PM
Posted 29 October 2009 - 10:05 PM
Should I be concerned that my next door neighbours fish are floating on the surface of their pond???!!
