Dot's Mini
196 replies to this topic
#91 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 11 October 2009 - 07:47 PM
Great work, you certainly don't hang around. I'm glad mine doesn't need the full quarter panel.
Not half as much as I am!!!
After today I don't want to see another one for a while.
Yours is tucked up nice and safe in the neighbours garage now :P
Oh brilliant, thanks :thumbsup:
Hope you didn't have too much trouble when you turned up with it on your drive without mentioning it to your wife.
I'll tell you when she starts speaking to me again!! :thumbsup:
#92 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 16 October 2009 - 04:42 PM
Well theres a queue forming for peeps who want welding so I'd better get me finger out!!
I finished fitting the rear 1/4, looks really good as well!!
Fitted the new rear valance and stiffeners
The gutter rail was looking a bit ropey so I welded it up,
At some time some 6x9s had been fitted to the rear shelf and the metal work had been butchered, couldn't leave it like this :D
So I fabbed up a repair patch and joddled the edges so it would sit flush and would also give a little bit of strength back as well.
Pleased with that, just got to do the other side and thats that done.
Jobs list is getting a lot smaller now.
Got to:-
- Finish off front end welding
- Finish off rear valance welding(welder won't reach at the mo!!)
- Repair hole in roof
- Fit and fettle passengers door
- Fit and fettle boot lid
- Fit and fettle bonnet
- Do a 1st run of filler on the shell
- Etch Prime
- Barcoat
- 2 coats of high build
Then its off to Roofless for the paint and finishing...........................Phew!!!
Edited by shiftyseamus, 16 October 2009 - 04:43 PM.
#93 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 16 October 2009 - 07:35 PM
Its looking great now, and good to see the list is getting alot smaller too!
What welding have you got to do on the front end?
James.
#94 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 16 October 2009 - 07:41 PM
Not that you've got a vested interest in the list getting smaller or owt, eh James??!!!
(heh heh)
The scuttle needs fully welding around the screen, just tacked at the mo, also a few other little bits, not much really.
I should get all the welding finished and ground back tomorrow, then on Sunday its filling and sanding.
Stick some etch on it during the week and we're nearly there!!
PHEW!!!
#95 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 16 October 2009 - 08:13 PM
No not at all, couldn't possibly think of any reason whatsoever :wub: :thumbsup: :D
Really is looking brilliant again. Is it going to be resprayed in the same colour? and is the kit going back on?
#96 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 16 October 2009 - 08:26 PM
Nor sure about the colour, I'm pretty sure its gonna be a pink purple vibe again??
I think Dot wants the body kit back on, not my taste but its not my car. All that stuffs Martins dept, he's got the paitience to mess with fibre glass. I hate it, it always melts when I try an weld it on!!!
Hopefully Dot will be along soon to confirm or deny the rumours!!
#97 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 17 October 2009 - 01:07 PM
And I thought I was winning the race for the paint!!
Looking good Shifty
#98 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 26 October 2009 - 07:37 PM
Right well, I've been busy(again!!)
Dots WILL be going to Roofless for paint this weekend so I've been pulling my finger out!!
So.......
Played with passengers side door to get the gaps spot on
Had to go a bit of welding and grinding but the results were worth it!!
There was a little rust hole in the roof..
Which I promptly turned into a BIGGER hole!!!
And then welded up and ground down!!
Pleased with that as well, bit of a filler skim and you won't know its there!!
I've also welded up the other speaker hole, and started to prepare it for priming.
By the weekend it will have
- Etch prime
- Bar coat
- 2 coats High build primer.
Then its just a quick seam seal and Roofless can have it!!
Watch this space!!
#99 bamby
bamby
  • 1,342 posts
  • Local Club: Fylde Mini Club
Posted 26 October 2009 - 07:54 PM
Looking good Uncle Shifty! keep it up and you'll be home and dry :D
#100 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 26 October 2009 - 08:23 PM
Come on Shifty
Chop chop now :D :-
#101 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 26 October 2009 - 08:26 PM
By the way
You make it look too easy!!
#102 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 27 October 2009 - 08:25 PM
I'll chop chop you in a bit!!!
(heh heh heh)
Be patient my Monkey Mate!!!
Anyway, been at it again.
I've finished off the prep on the apssengers side and it looks pretty damm good!!
Door gap after grinding and welding.
Started to prep the boot lis and found a wee bit of rust, so ground it back and treated it.
Also 75% finished the filler on the drivers side, just gotta do the door.
Aiming to have it in etch primer on Thursday night, really looking forward to seeing it in primer, should look fantastic!!
#103 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 27 October 2009 - 08:32 PM
Awesome work shifty, also can't wait to see it in Primer! :)
#104 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 27 October 2009 - 08:34 PM
looking superb - detail on the door shut is excellent
#105 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 27 October 2009 - 08:35 PM
That door gap is probably better than when it left the factory!!
