there all ive got.. hvlp ones.. good for celly if thats what our spraying. 2k is also good to use.. nice finish out the gun with a nice hard wearing surface.did you say you were going for concours like Frog said?
Hi
yes, i am aiming for concours finish with celly. How easy is celly to spray? I am looking to buy the Divilbiss GTI pro air gun, but it socts over £200. I dont know if i might be wasting money, as I dont know how much use it will get after i finish painting this mini.
Hi john,
Spraying celly is quite simple, apply relatively thin coats (you can't put it on as thick as 2k) & build them up, normally I would look to do 2-3 coats of 50/50 mix then last coat thin to between 40/60 or 30/70 obvoiusly this is thinner so apply carefully & try not to get any runs. Most spray jobs are ruined by people rushing them.
Hi
I have bit the bullet and have ordered my spray gun from spraygunsdirect. I have gone for the DeVilbiss GTI pro, with T1 cap and 1.3 fluid needle. I hope this gun will give me a good finish, if i follow the advice given about building up the coats gradually. I am in the process of prepping prior to adding barcoat, and celly primer filler.
This might sound like a silly question, but what is the definition of prepping? Does it mean it includes the filler stage, or just prepping surface quality, degreasing etc before paint application? I hear a lot about 90% of the final finish is in the prep.
