Edited by Danuneek, 18 August 2009 - 09:54 PM.
Posted 18 August 2009 - 09:44 PM
Posted 18 August 2009 - 09:57 PM
Posted 18 August 2009 - 10:05 PM
it must be a heftey hole to couse juddering of some sort but never the less possible.. if it is blowing for sure youd need to sort it sooner rather than later as its obviously not good for ya lump.lol it does take abit of hp away from the engine when its blowing but.... i dunno haha
Posted 18 August 2009 - 10:08 PM
Posted 18 August 2009 - 10:11 PM
Posted 18 August 2009 - 10:13 PM
Posted 18 August 2009 - 10:14 PM
well id say if it was blowing you need to fix it anyways so.. crack on and then see if it stops..
haha best way i spose.. but yeah there maye be a few certain pints were gasses are more prominant in rev ranges and what not.. could cause some affects like that..
Posted 18 August 2009 - 11:00 PM
Iv had the exact same thing on my 99 MPi. Juddering whilst driving with exhaust blowing and having to keep the revs up.
Is ur car an injection? and my problem was an electrical connection to the right of the throttle body. There are 2 connections identical. Id give all the connections a good check over and make sure they are contacting properly. Hope this sorts it. I KNOW that JUDDERING FEELING!!
caused me alot of hassle. Get it seen to if not or try and sort it as mine got gradually worse and eventually i basically couldnt let the clutch out without the poor thing coughing and spluttering
Also have the engine on idle and pull it towards you when u are standing at the front of the car, mine would cough and splutter when i did this.
Hope this helps
Edited by Danuneek, 18 August 2009 - 11:13 PM.
Posted 19 August 2009 - 01:31 AM
Edited by jkjaxor, 19 August 2009 - 01:31 AM.
Posted 19 August 2009 - 02:22 AM
Posted 19 August 2009 - 09:34 AM
Posted 19 August 2009 - 11:07 AM
A blowing exhaust will cause a weak mixture, if left for to long and thrashed chances are you will burn out a valve.
Edited by Danuneek, 19 August 2009 - 11:07 AM.
Posted 19 August 2009 - 01:05 PM
