Fuel Capacity
Posted 18 August 2009 - 01:00 PM
Posted 18 August 2009 - 01:08 PM
What is the real world (without overfilling) fuel capacity of the stock Rover Mini Mpi petrol tank?
Supposed to be 7.5 Gallons and you can probably nearly get that amount in with bit of "trickling" but it's knowing what you have left as the gauge is crap!!
You should never let it get down to the last half gallon as it will draw al the "poo" out the bottom so I would say you have a 6 to 6.5 "usable" gallons i.e. 230 to 250 miles depending on MPG, i.e. state of tune and driving mode?
Why ???
Posted 18 August 2009 - 01:39 PM
Why ???
I think the capacity on injection fuel tanks is slightly less that 7.5 becuase of something that sits inside it, possibly the fuel pump or something else.
Posted 18 August 2009 - 01:58 PM
Posted 18 August 2009 - 11:42 PM
Posted 18 August 2009 - 11:44 PM
The maximum I have been able to put in an MPI tank is 6.5 gal (7.8 US gallons.) This was after I ran out of fuel on a level surface, so the tank was as low as it could get while actually being in service. It probably had .5 gal already in it from the fuel can I used to get the Mini to a fuel pump.
I would say that the "last" gallon, if it's there, is unusable. So allowing for a reserve, I try to fill up around an estimated 4.5 gallons (Imp.) mark.
Posted 19 August 2009 - 02:24 PM
Replaced and looked at the old one, basically its of the wire wrap and slider arm configuration
The bottom end of the wire coil was broken so essentially it showed empty well before it was was.
New sender seems to be doing the job right.
Posted 19 August 2009 - 02:27 PM
I've never understood this - is the petrol not drawn from the bottom anyway? Also, what kind of rubbish gets in the fuel tank?
Posted 19 August 2009 - 09:04 PM
If I could shift the gage sweep slightly downwards, I think it would be pretty accurate. For me, the gage moves off of the full mark very quickly, then takes a while to go through the last quarter of the sweep. True empty for me is signficantly below the empty mark.
Posted 22 August 2009 - 12:02 AM
I don't know if my sender is broken. Inaccurate fuel gauges seem to be a pretty common complaint for MPI owners. But I watch for the gage needle to go just below the "E" mark. At that point, I have about 1.5 gallons left, and it's time to go look for fuel.
Mine is exactly the same.
Posted 22 August 2009 - 11:29 AM
PS - My gauge shows empty and still has 2.5 > 3 gallons remaining. As long as it's consistant, you should learn when to fill it
Posted 24 August 2009 - 05:45 PM
when im red line and think hum i better put some in if i say put a 5er in it sometimes wont move off redline and its only about £24 to fill mine so a 5er should show alot
bloody car
Posted 26 August 2009 - 12:09 PM
the fuel is drawn from above on injection minis (well, mpi's anyway). carb'd minis draw fuel from almost the bottom of the fuel tank. its a good idea to run a fuel filter on carb'd minis anyway, an inline filter costs a couple of quid plus some pipe clips. injection minis have fuel filters fitted as standard, as the tiniest piece fo dirt can clog the injectors up.
Posted 26 August 2009 - 12:29 PM
-Jamie
Posted 15 May 2010 - 09:46 AM
Fuel is still taken from the bottom of the tank! In a similar way to using a drinking straw the fluid is drawn from the bottom of the glass. Picking up the silt from the bottom of the tank is in the best part a myth these days unless a really old and rusty tank has been reused after having been sat around rusting internally.You should never let it get down to the last half gallon as it will draw al the "poo" out the bottom
