Looking back over the last few months i don't seem to have done to much to this project, I blame visiting Mini shows and generally getting out and about, now that autumns here, lets hope for some more "shed time" its difficult to remember in what sequence i have done each part on this build but i will try to get things in the right order
I produced a bracket to mount my three fans onto the oil cooler
These are now to be controlled by a adjustable fan controller the sensor can be seen here
I think this is the point where i got thoroughly pished off with the wiring, especially the electric reverse
At this stage I am thinking that I may try to avoid IVA if I can, but where I can I am building in certain things that would mean major re-work if ever the vehicle was presented for test, one of those is the steering column, I had read somewhere that the Metro column would provide a good starting point and fit the Mini rack, so off to the local car breakers
With careful measurement and counting it was concluded the the Mini rack spline is 9/16 x 32 another trip to the breaker i returned with a universal joint that seemed to be correct but when offered to the rack it didn't fit
About the same time my 4-2-1 exhaust arrived from Z-cars, a lovely piece of work
It was now clear that i would not be running my engine for a little time yet so i decided to do something different and remove the standard Mini front subframe and fit my Z-Cars version, this would allow me to investigate the steering rack spline problem and then work on finalizing stuff on the front end.
With the subframe removed i was able to remove the rack and could now see that the 9/16 x 32 spline was indeed correct wedging a chisel in the split of the universal joint had the universal joint sliding on perfectly, it turns out the Minisport (brand new) rack had a slightly oversize spline the Minispares sportspack rack i have now bought is perfect..........
