'busavan
#31
Posted 24 April 2011 - 08:57 PM
#32
Posted 26 April 2011 - 01:27 PM
#33
Posted 27 April 2011 - 12:00 PM
Top work there boys, would be good to see a load pf pictures in an update......
Working on a update right now
Just have the misery of re-sizing my pictures to deal with tonight....
#34
Posted 29 April 2011 - 07:41 AM
The past few months have been exciting and frustrating in pretty much equal measure,
In a fairly concentrated effort to get my engine running I bought lots of bits and pieces including this for a few quid from the far east
I ordered and fitted my oil cooler and had some nice braided hoses made up by the local PIrtek man.
A sorry saga surrounds the purchase of the two very expensive sensors that were missing from my loom with the Suzuki dealer going bust two days before i could collect my (paid for) sensors
I sent my wiring loom to Chris at Z-Cars for modification and it was duly returned a lot smaller and lighter with nice clear labels on how to connect it up, I made a temporary "engine control panel" with my nice new Stack water temperature and oil pressure gauges and a few switches to control ignition, start and clutch switches.
The idea was to turn the engine over to at least put the oil light out before introducing fuel and going for a start up, all went well but we had no fuel pump relay "click" and no spark, time spent pouring over the wiring diagram it could be seen that these two systems share some wiring, a chat to Chris suggested inspection of the resistors that he had installed in the loom, these proved to be in place and the correct value, Chris seemed a little baffled and asked me to return the loom to him, I also found some "pin-out" diagrams for the ECU that he said may help.
I also removed the engine side cover to help identify the age of the engine.
Maybe because this is a van and not a car i had to extend the gear cable, i did this with some threaded spacers, i did not have suitable material to hand so these are just to see if it all works and with the gear cable in position it will allow me to position and fit the coolant, fuel & brake pipes in the tunnel.
Try as i might i could not get the supplied gear cable bracket to fit, i have no idea why so i made my own, it functions but needs a brace and paint to finish off.
For the initial start up I botched up the cooling and fuel systems with the pipes not yet fitted to the shell and the rad just sat on the floor in front of the van
Made a handbrake bracket as mine was missing
Header tank polished (thanks Mike)
Throttle bodies fitted and fuel pressure regulator fitted.
Throttle cable fitted to the throttle bodies with modified bracket to allow the addition of an extra return spring.
Edited by rustandoil, 29 April 2011 - 10:48 AM.
#35
Posted 29 April 2011 - 07:48 AM
The panel is held up by a cupboard door type catch
The original idea was to have all the wiring run to the engine and back of the van through cable sleeving up the passenger side windscreen pillar and along the top of the door, as the wiring in the loom grew i have had to split this so that the lighting wires run drivers side
To distribute power have made a insulated block (will be remade properly) one terminal bolt is permanent live and the other is ignition live, this made it easy to add circuits as i built the loom.
Most of the circuits return to a single earth point, there are a number of unfinished areas but most circuits are present and working.
Another temporary thing is my dash installation which was lashed up while waiting for the foamboard that i will use to make the final version, this lash up has allowed me to make the dash loom and its connections to the correct lengths.
With my engine loom back from Z-Cars i was then in a position to start the engine from the key with the warning lights and other instruments working, again i turned the engine over until the oil light went out, connected power to the fuel pump and pipes to my now polished (thanks Mike) fuel tank, the engine took a little time to start but start it did! a massive sigh of relief to hear that!!
I borrowed a fitting from brother-in-law to direct the exhaust away from the shell
It sounded fantastic! and considering that i only revved it up to 4000 RPM impressively loud...
I have since run the engine up to temperature and everything was fine no leaks or other problems
Now that my engine loom is proven to work i have removed it from the car and stripped it to get some of the wires to exit in different places particularly the crank sensor wires that were particularly tight when installed on the engine.
So work has now started on the bulkhead, again temporary due to limited materials, its going to be a full height effort with a window i have started by attaching a bit of B&Q's finest aluminum to the roll hoop to which i can fasten a sheet of ali to make the passenger side bulkhead panel that will then allow me to layout and fit the engine electrics, ECU and battery in their final places
This arrived this week
Thats all for now but i am going to make a effort to update this thread more regularly and therefore reduce the pain of dealing with re-sizing phoits and dealing with photbucket
#36
Posted 29 April 2011 - 10:21 AM
Its coming on really well, loving some of the touches you've done. puts my wiring to shame!
Les.
#37
Posted 04 May 2011 - 11:27 AM
#38
Posted 04 May 2011 - 12:38 PM
#39
Posted 24 May 2011 - 06:08 PM
I have needed to wire in two relays to get the Geartronics indicator to only enable the reverse circuit when in neutral and the second so the display shows "R" when reverse is activated.
I have also decided to have a timer relay for the heated screen and have the relay for the rad cooling fan all in one place, I was also looking at the load that goes through the ignition switch to power all the ignition controlled circuits, so have elected to install a monster relay (100A) to take the load and provide tidier distribution posts for my loom, pictures to follow when its a bit tidier;)
While I was re arranging my loom so that some of the wire runs were better I was able to remove stuff like this....
I also made quite a neat bracket for the ambient air and intake air pressure sensors
With the the loom layout pretty much as it will finish (except for taping) I have started to mount the various components on a temporary piece of ali sheet, ignore the spare holes and lack of grommets.
Bulkhead side panels will have this detail on their outer edges
The engine supply / car connections from front to rear will go through these connectors, probably not the best quality but should be ok in the dry, again this is temporary with the connectors attached to wires that are waaay too long.
After initially eliminating the clutch switch from my plans this happened to my boy, he was stood between two cars when one of then was accidentaly started in gear..........
So I have decided to incorporate the clutch switch in my build...................
I bought this but it seemed too fiddly to fit.
So i went with a micro switch this is the Mk1 version my next effort is way better and you will have to wait for a pic of that
I have bought these bad boys to fix to the oil cooler I intend these to run all the time the ignition is on
Oh and it seems Santa came early........................
#40
Posted 08 June 2011 - 11:37 AM
Update as promised
more to follow
I built up the front uprights and fitted them to the front subframe, with the adjustable bottom arms and tie rods, I bought some new drive flanges from IMM but have since learned that they wont fit with the Metro 4 pot calipers and the vented discs, so I left the discs off so I could get the subframe under the van and get the front end on wheels.
I also bought some new CV joints at IMM and cut them down as of course I don't need the drive cup, having read another build thread it seems as if I may have cut them a little short doh!
All this is temporary as I am going for the Z-cars front subframe.
Also purchased at IMM
are these the goodies your talking about mate..... il have the lot when for sale, hopefully soon
any progress on the van anyway?
#41
Posted 08 June 2011 - 12:42 PM
PM sent
#42
Posted 10 November 2011 - 07:54 AM
Edited by rustandoil, 10 November 2011 - 07:56 AM.
#43
Posted 10 November 2011 - 09:35 AM
Edited by rustandoil, 10 November 2011 - 09:36 AM.
#44
Posted 10 November 2011 - 10:04 AM
Its coming along great guns. I really would like to put a bike engine in my van one day, Dont think I could come to terms with cutting the load bay out though, maybe a pro-motive front engine kit at some stage.
Is this the first conversion do you know? cant say i've seen any other bike vans.
#45
Posted 10 November 2011 - 11:06 AM
I have written what has turned out to be quite a large update
I don't know how many bike engined vans there are but at the time the original owner ordered it (i bought it as an unfinished project) it was the first van they had done.
