How To Fit Rear Seat Covers
3 replies to this topic
#1 leonie_wray
leonie_wray
    Starting My Mini Up
  • 4 posts
Posted 16 August 2009 - 09:11 PM
Hello
I bought some rear seat covers today at MITP to match my front cobra classics. The back seat at the moments is just a gray cloth thing...velor? out of a mayfair.
Do I need to remove the gray or can I put the new one over it? and also ...how do i do that?
#2 monster_mini
monster_mini
  • 981 posts
Posted 16 August 2009 - 09:43 PM
i think you just put it on top, it depends as i have seen loads of different ways of people attaching them
nick
#3 The_Mistro
The_Mistro
    Farmer Barley Mow
  • 2,369 posts
Posted 16 August 2009 - 09:49 PM
when i did mine, i took the cover of the upright part, because i needed the clips from it to put the new 1 on, and then put the one on the botton over the top of the old one, and staple gunned it in place!
#4 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,851 posts
Posted 16 August 2009 - 10:07 PM
First, on the top half, you need to remove all the clips from the rear. I used a flat head screwdriver.
After you've done that you reattach the new one with the reverse method. Using some glue on the foam of the seat to keep the seat cover from flopping.
For the bottom one, you need to simply pull the old cover off, leaving only the foam and a small piece of hardboard.
Attach the new cover with some glue, pulling it tight as you can, and then using a staple gun (a high powered one), secure the front by stapling the vynil to the hardboard.
Best of luck :lol:
