Electrical Modifications
#16
Posted 17 August 2009 - 08:16 PM
#17
Posted 17 August 2009 - 08:21 PM
Am I right in saying then that the dim-dip relay draws it's current that would originally drive the headlights from the inline fuse, and it's feed from the main fusebox is a switch feed? I might be wrong though, since I'm no electronics expert.
Yes, the fused supply to the dim dip system from the fuse box only runs the relay itself. The feed that would originally supply the lamps however is exactly the same as it would be in a car without the system. The dim-dip doesn't exist to isolate the lamp load from anything, all it does is switch the lamps on automatically if you try to drive using the sidelights only. In those circumstances the other dim-dip feed (the inline fuse) is used to supply the lamps independantly of the switches but in all other conditions the circuit is unaltered from the earlier system.
#18
Posted 20 August 2009 - 05:52 PM
#19
Posted 20 August 2009 - 06:56 PM
#20
Posted 20 August 2009 - 09:45 PM
Anyone got one spare??
The late SPi fusebox was only ever made as an integral part of the loom, it isn't available anywhere.
#21
Posted 21 August 2009 - 02:11 AM
#22
Posted 21 August 2009 - 04:15 AM
http://www.merlinmot...mp;currency=USD
#23
Posted 21 August 2009 - 08:59 AM
Ooh, this one looks like it'd be just the right replacement for the OEM box:
That only has 4 male connectors per side, the original has 8
#24
Posted 21 August 2009 - 06:53 PM
Edited by Brams96, 21 August 2009 - 06:54 PM.
#26
Posted 05 January 2010 - 06:35 PM
everyone else on here says there roughly double the rating.....i.e a 15A blade fuse would blow at 30A...where as a 35A glass fuse blows at 35A...the blades rating is there constant current rating...as in the rating there desinged to constantly run at...atleast thats what i have been told by a couple of people on here.....the displayed value on the blad is only half of what it takes to blow it
This doesnt make any sense to me at all. The numbers on a fuse are the maximum current that can pass through it before it blows protecting the circuit that it is part of not its constant current rating. A 15 amp fuse will run constantly at a tad under 15A until that is exceeded then it will blow. I have never heard such rubbish advice given out.
#27
Posted 19 January 2010 - 10:40 PM
thanks
#28
Posted 19 January 2010 - 10:51 PM
Then perhaps you should try finding things out rather than just assuming you know.
That isn't true. Blade fuses are rated at what they are designed to run, not at where they blow. A red blade fuse with 10 stamped on it has an instant fail rating of 20 amps. Look it up. Between 10 and 20 amps it will just heat up and eventually fail but it will take a while, during which time it may well start a fire. This is why electrical design should be left to people who know how to do it, and you should never simply assume you know enough to design a system.
#29
Posted 19 January 2010 - 10:56 PM
#30
Posted 19 January 2010 - 10:57 PM
