No Brakes - Pedal To The Floor!
21 replies to this topic
#16 Cooperman
  • 23,276 posts
Posted 14 August 2009 - 09:46 PM
You're welcome. We are all here to help each other.
#17 Adcuz
Adcuz
  • 843 posts
Posted 15 August 2009 - 11:36 AM
OK, so I've just had the rear drums off and have found the nearside cylinder to be leaking, as said previously, so thanks all! I'll order all new bits.
#18 bmcecosse
bmcecosse
  • 9,699 posts
Posted 15 August 2009 - 12:28 PM
Change both sides - and new shoes too. Free off the levers and the quadrants - and the rear brakes will be as new! No more problems for a year or two - with luck.
#19 minipip
minipip
  • 1,591 posts
  • Local Club: TMF SE
Posted 15 August 2009 - 12:45 PM
GOOD LUCK WITH THAT CIRCLIP!!!!!
lol
#20 Adcuz
Adcuz
  • 843 posts
Posted 15 August 2009 - 12:56 PM
I'm just about to order new shoes, springs, cylinders and bleed nipples for good measure :mrcool:
With regards to "that circlip". Anyone care to enlighten me on any special precedure to remove them? :D
EDIT: Noticed bleed nipples come with cylinders anyway
Edited by Adcuz, 15 August 2009 - 01:14 PM.
#21 minipip
minipip
  • 1,591 posts
Posted 15 August 2009 - 01:16 PM
removing them is the easy part, get a screwdriver in and PING it will come off.
putting it back on will involve a lot of twisting pushing swearing just persist!
#22 bmcecosse
bmcecosse
  • 9,699 posts
Posted 15 August 2009 - 01:21 PM
Goes in easy - just use a largish screwdriver - get it started on the middle leg - then pop the other two in by leaning the screwdriver on them. 5 second job. Simples!
