1979 Austin Mini 1000 Restoration
#31
Posted 05 November 2009 - 03:18 PM
#32
Posted 07 November 2009 - 05:14 PM
remember a while ago when i said the building i work in floods? well guess what, it's done nothing but rain all week and now look:
that's not even as deep as it's been. you can see the water line on the side of the tyres where it's been! well, i thought, i'm not working in that! my dad had a little water pump that did actually remove a lot of the water after 2 hours but by this time i had had enough so i went home lol
on a brighter note my new panels have turned up from minispares. i have a new door step, inner sill, inner flitch repair and a genuine A panel for the O/S. i did make a start today by cutting a brace bar for the door ready for when i start cutting the rot out.
apparently the weather is going to be good tomorrow but i'm racing instead
#33
Posted 07 November 2009 - 09:48 PM
#34
Posted 15 November 2009 - 06:16 PM
i've been busy for the past 3 days working on that terrible sill. that means i have lots of photos!
i started by removing the old flitch panel. there were 2 repair panels welded on top of the original panel!
Removed the old door step.
then i removed the door hinge stiffener panel which also had a repair panel welded over the top of it
chopped out the old inner sill panel and welded in a new one.
this is how it looks so far with new inner sill and door step welded in place. finsihed with grey oxide primer which is great stuff compared to spray primer. sorry about the rubbish quality. it went dark at 4 and i had just finished for the day. i'll take some better pics next time.
my new door hinge stiffener panel is on it's way from minispares and should be with me soon and hopefully welded in by my next update. once that's in i can then weld the flitch and sill panel in place. it's all starting to come together now. still a looonngggg way to go till it's all finished though
#35
Posted 15 November 2009 - 08:57 PM
Your poor grinder must be worn out!
Keep up the good work.
Have you got a completion date in mind?
#36
Posted 15 November 2009 - 11:02 PM
i was hoping to have it finished at least by this time next year but at this rate it should be sooner.
#37
Posted 16 November 2009 - 07:29 PM
apart from the grubby engine it didn't look too bad did it?...... how wrong i was!!!!
#38
Posted 22 November 2009 - 07:31 PM
haven't got much done this week thanks to the wonderful british weather and having to work on my other car for its mot. at least the building wasn't as flooded as it has been up north this week
however, i did manage to get one days work in and fitted the new door stiffener panel and flitch welded in place. also gave the whole underside a paint with grey oxide primer.
#39
Posted 23 November 2009 - 01:35 PM
#40
Posted 23 November 2009 - 06:10 PM
#41
Posted 13 December 2009 - 04:42 PM
that'll be it for another few weeks, going on holiday this saturday!
#42
Posted 20 December 2009 - 07:31 PM
#43
Posted 20 December 2009 - 08:23 PM
#44
Posted 11 January 2010 - 08:47 PM
tis' now painted but forgot pictures
#45
Posted 11 January 2010 - 09:06 PM
