Front Shock Mount Repair To Inner Wing
Posted 12 August 2009 - 09:11 PM
Posted 12 August 2009 - 10:46 PM
Posted 12 August 2009 - 10:50 PM
Posted 13 August 2009 - 07:07 AM
Worth checking surrounding areas within 10.5foot
10.5 feet, that's the whole car then! Perhaps you mean inches, buddy...
The area behind the shock mount is easily replaceable thought you must be ablet o weld well as it is a critical part- you might want to keep an eye on my project thread as i will be welding this repair in myself on my project - easy to get to providing the shock mount comes off easily - the bolts can be rather tight sometimes and often very rusty.
As said above - Brace bars have nothing to do with the shock mounts, They're simply to replace the inner wings once they've been cut out - But once you have solid mounted the subframe (as you should with flip fronts) the bars will do very little and as such really are just MOT pleasers.
Even some Miglias don't run bars...
Posted 13 August 2009 - 12:32 PM
Yeah you can repair this area yourself, I take it you mean a hole directly behind the top shocker mount itself. I have just repaired this area on both sides of a customers car, cut out the bit of rot, treated then made up a repair plae & welded it in. Then refitted the shocker mount back on.Just found R inner wing has rusted right thro behind shock mounting bracket when I took it off. Can that area of the inner wing be cut out & a patch welded in readily and does it require major stripping down to carry out? I'm not looking at attempting it myself. Thanks
Posted 14 August 2009 - 07:29 PM
Posted 14 August 2009 - 07:32 PM
Posted 14 August 2009 - 07:36 PM
Posted 14 August 2009 - 07:49 PM
Repair panel I made myself, just gotta drill the shock holes.
