Chrome Bullet Door Mirrors Are To Low!
11 replies to this topic
#1 Howie1000
Howie1000
  • 124 posts
  • Local Club: Cornish Mini Club and Mini7
Posted 12 August 2009 - 12:36 AM
Hi all,
I have a set of the chrome bullet style mirrors for my mini doors, the prob is that when in position they are actually to low, (I cant higher them as they'd be in the glass) I've see fitting kits in Minispares for 1980 onwards doors, but mine is a 74 Clubman, is there some sort of bracket I can fit 1st to angle the base up a bit?
Many thanks for your help & suggestions
David.
#2 Prawn
Prawn
  • 938 posts
Posted 12 August 2009 - 07:14 AM
Sadly, if you have the mirrors with a non adjustable base that just bolts to the door, they really are totally useless!
those type of bullet mirrors are really just for show I'm afraid.
the slightly better ones are those which have a base that bolts to the door, then the mirror sits on a vertical upstand and the whole bullet body can be turned/twisted to suit.
#3 Jake Blues
Jake Blues
    TMF Moderator
  • 2,955 posts
  • Local Club: Central Minis
Posted 12 August 2009 - 08:02 AM
I'm assuming you have tried adjusting the mirror part? If not...undo the screw at the point of the bullet a bit until you can move the mirror.....
(It looks obvious but I met someone at IMM who didn't know they were adjustable)
#4 richieg
richieg
  • 165 posts
Posted 12 August 2009 - 08:55 AM
There are 2 types of bullet mirror, one with fixed arm and one with adjustable arm.
i have the fixed arm and have the same trouble. I think these are actually wing mirrors , not door mirrors which is why they sit sl low (mounted sideways on door instead of upright on wing)
#5 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 12 August 2009 - 09:06 AM
These are wing mirrors:
>>click me<<..
They offer next to no visibility if fitted to doors and are just dangerous. Not designed for doors - if you have bought these - sell them or send them back. Or fit them on the wings where they'e meant to go.
These are the Door mirrors
>>click here<<..
You can see that they have an arm on them - this is to raise them up so that you can see out of them and gives the mirror full adjustability. Very good mirrors, easy to adjust and great for looks. To fit these you'll need the fixing plaque too which is supplied with most aftermarket mirrors made to go on standard door fixings:
>>fixing kit<<..
Most people buy the Wing mirrors without realising it - and unfortunatley - most sellers list them wrongly - Minispares do not however... they list them correctly - buy from dealers that know what they're doing...
#6 jaydee
jaydee
  • 8,565 posts
Posted 12 August 2009 - 09:34 AM
Its better to fit them without any adaptor, just drill a couple of holes in the door to fit the original base.
#7 rendersonique
rendersonique
  • 386 posts
  • Local Club: http://www.dcmoc.co.uk
Posted 12 August 2009 - 09:39 AM
I had a similar problem with my 68 cooper S. I bought the mirrors and used the existing bracket. The problem was that the original bracket had a 70-80 degree lift on it making the mirrors hit the window leaving me in a position where I could not adjust correctly. I was given a set of new mounts that had a 25-30 degree lift that dropped the mirrors and enable me to adjust so that I could see behind! Always a bonus :D The only issue I had was that I had to tap another hole in the door as the original ones were not in the correct place.
Edited by rendersonique, 12 August 2009 - 09:40 AM.
#8 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 12 August 2009 - 10:48 AM
how is drilling holes in the doors and using bolts better than doing the job properly? - Using the original rivnut mountings and well known 'tex' type mirror plaques. the plaque also has the bonus of lifting the mirror higher up for ease of adjustment - particularly useful on the passenger side.
#9 jaydee
jaydee
  • 8,565 posts
Posted 12 August 2009 - 11:03 AM
The original base doesnt use bolts (bolts have not to be used to that purpose!) it uses rivets and screws.
I have one fitted the original tex base by drilling holes thrugh the door (mainly because original holes where messed at a so called bodyshop..); and have fitted the other one using the adaptor.
I found that adaptor gives very poor fitting, while the other mirror is solid rock mounted.
Edited by jaydee, 12 August 2009 - 11:04 AM.
#10 Howie1000
Howie1000
  • 124 posts
Posted 12 August 2009 - 01:22 PM
Cheers for the info guys, unfortunately it is the 'wing' mirrors that I have >_<
Does that adaptor kit just enable the mirror to be fitted without drilling further holes or does it change the angle of the mirror?
#11 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 12 August 2009 - 01:28 PM
The fitting kit for the door mirrors changes the angle slighty (by lifting the mirror) and doesn't need any holes other than the rivnuts that were originally in your door >_<
#12 stormintrooper
stormintrooper
  • 2,072 posts
Posted 12 August 2009 - 01:31 PM
>>click here<<...
i have noticed..i have a pair of these...and my left hand side one has to be angled to a stupid position for me to see stuff...i twist the lens but it does not adjust like the driver side one does
