Jeez
Good thing the little boy got out just before huh?!
Posted 05 September 2009 - 09:52 PM
Posted 06 September 2009 - 09:05 PM
Jeez
Posted 06 September 2009 - 11:00 PM
Posted 07 September 2009 - 03:57 PM
Posted 07 September 2009 - 08:01 PM
looking good, as far as your electrical problems I'm afraid you've just got to start tracing and testing wires.
I had a similar problem with the lights and found some of the wires had gradually worn through in the loom (remember that the rear loom enters into the chassis at the engine bay and runs to the rear through the chassis). ended up byassing most of mine with new wires as I had the added extra of a military light switch with all different settings for the lights
Posted 08 September 2009 - 09:34 AM
Posted 08 September 2009 - 07:01 PM
Posted 08 September 2009 - 09:17 PM
Posted 10 September 2009 - 12:06 AM
Posted 10 September 2009 - 03:17 PM
Posted 10 September 2009 - 04:17 PM
yes, that is the oil cooler and it is needed unless you have a tdi radiator to use with the oil cooler built into the side. (two steel pipes going into the drivers side of the rad). the v8 should slot into your gearbox without problems you will just need to weld in some new engine mounts. wiring is supposed to be fairly easy, use the engine loom off the discovery then theres only about 4 wires that need joined into your 90's electrics.
also think you will need to change the fuel pump
Posted 10 September 2009 - 05:02 PM
sorry I didn't really make any sense about the gearbox (I am just about 30 lol) right I'll start again you need to use the lt77 gearbox from the discovery which will slot straight into your 90, this is important as the bell housing is different and longer so you need the discovery box for the correct length of input shaft. the longer bell housing brings your engine further forward but in the correct position for a v8 which is why you need to weld in new engine mounts. phew I think thats got it lol.yes, that is the oil cooler and it is needed unless you have a tdi radiator to use with the oil cooler built into the side. (two steel pipes going into the drivers side of the rad). the v8 should slot into your gearbox without problems you will just need to weld in some new engine mounts. wiring is supposed to be fairly easy, use the engine loom off the discovery then theres only about 4 wires that need joined into your 90's electrics.
ill buy a new oil cooler from foundy 4x4 asap
id rarther use a separate oil cooler so i can use the v8 rad which is a lot bigger and has no intercooler
the v8 is from a discovery which used the LT77 box,when i did my 200tdi it used the same box but needed stud mods so how dosent this need it? i find it rarther strange unless because its the same engine as used in range rovers and 90s they are made to fit all boxes?
how do i need to weld in new mounts? the v8 used the same mounts as the orginal 90 engine in the same places? unless its advised to use the bigger 200tdi discovery mounts?
wiring to be honest looks horrible i have a massive loom that needs separating and its also an EFI (injection) engine so that makes it 10 times worse
fuel pumps i think were electric so ill use an aftermarket pump in the engine bay for easy acces
the 200tdi is now out and the rest of the front is off will post pics later on
thanks
Posted 10 September 2009 - 05:04 PM
thanks
Edited by racer36, 10 September 2009 - 05:05 PM.
Posted 10 September 2009 - 05:08 PM
the input shaft is different, I believe it is possible to strip down and change the input shaft but if you have the discovery box there then its only a couple of hours job to drop it out the discovery and fit into the 90ahh now i get it !
is there any chance of using the bellhousing and bits from 200tdi engine? also pics are commin in just a sec
