whats a safari roof?
it dosent look too bad but parts are gune be expencive for that as i havent seen many of theese around here
is the roof like a canopy or something?
by the way paying £122 for the series 3
any ideas if its good or bad fo the money?
A safari roof is a "second skin" above the normal roof providing an air gap between the two, this insulates the main roof from the heat of the sun so your land rover won't turn into an oven as quick as others lol.
£122 is quite cheap for one of these, did you get the v5 etc?
hi thanks i was wondering what it was for lol i havent seen one before !
i did not get the V5 but i checked on the dvla website and it is listed as sorn so it has not been sent as scrapped so hopefully shoulde be able to apply for v5
it was full of junk when i got it this morning but having a closer look it is in much better condition than i could have hoped ! it has a few holes in the passenger floor,1 or 2 small holes on outriggers and 1 pencil shape hole near the rear leaf spring tho the 2 middle doors need replacing as theres hardly anything left of them and the 2 front doors have lots of holes but can be repaired
the grille,seatbox and radatior were in the back along with what was left of the front seats the seats went straight in the skip
however that dosent seem to bad considering what i thaught it would be ! and the seatbox is perfect ! so is the rear door ! the roof lining is all there and is still white and the bench seats arnt in bad nick either
question for onefastmoke? will i be able to fit discovery axles if i remove the turrets the coil springs sit on? im planning on all discovery running gear and a defender 90 gearbox?
Edited by racer36, 26 August 2009 - 06:52 PM.
