Whats Best Thing To Make A 998 Go Fast
Posted 10 August 2009 - 12:34 AM
what is the best thing to amp up the power
i dont want to put in a vtec or r1 engine (stay with the 998 or upgrade to 1275)
i was thinking a stage 3 kit
http://www.minisport..._T-KMST001.html
is it any good and can i get stage 4 kit
please help
Posted 10 August 2009 - 01:08 AM
ive saved about a grand for engine bits
please help
For that money I wouldnt bother with a 998, get yoself a 1275 mg metro engine, and stage one kit it, and get a megajolt system.
Sorted.
Posted 10 August 2009 - 04:25 AM
Posted 10 August 2009 - 07:01 AM
for a grand, you could probably build up a nice 1293 motor, with a decent cam, rebuilt box, and probably around 80bhp.....
Posted 10 August 2009 - 08:06 AM
I've got a 1015cc with a 12g295 cooper head, SW5 cam, light flywheel and lots of other nice bits on it.
I spent about £1200 on parts alone, no labour costs as I built it myself.
However that was a for a full rebuld inc gearbox/rebore/crank grind etc.
I got 50 at the wheels and 68 at the flywheel.
Posted 10 August 2009 - 08:26 AM
998 tuning isn't cheap but is very do-able!!
I think that proves my point exactly! Whilst Seamus will have a lovely engine, and he obviously wanted to tune the 998 because it's a fun little motor, all that work has resulted in an engine that puts out less bhp and less torque (almost certainly) than a standard 1275 MG metro engine.
Unless you have a reason to tune the 998, you're much better off going for a 1275 as a base to start from.
Posted 10 August 2009 - 08:39 AM
Prawns right, I could have gone the easy route and chucked in a 1275, wheres the fun in that???
The next stage for me is a supercharger!!
The thing is, tuning a 998 costs the same as tuning a 1275.
Instead of going 998 and overboring I could have started with a 1275 and done a 1310 lump, 12g940 ported head and done it to a similar spec to my smallbore. That would have probably given me say 85bhp.
I went the smallbore route just to be different and I had some parts like the head lying around, I also had a spare 998 kicking aound.
Getting power out of an A-series isn't cheap!!
So to answer your inital question....the best thing to make a 998 go fast is MONEY!!!
Edited by shiftyseamus, 10 August 2009 - 08:41 AM.
Posted 10 August 2009 - 08:44 AM
I've got a 998 stage 1, and I'll admit I've thought better cam, 12g295 head, plus 80 thou etc, but I've just travelled 300 mile to Cornwall towing a trailler filled with camping gear (8 man tent etc), 3 people in my car plus luggage. It had plenty of power, sat at 65mph on the motorway and had plenty left, no problems on hills, 44 mpg. Then we did 300 mile back.
After that if I did modify it would just be bragging rights and for the eck of it.
Edited by lrostoke, 10 August 2009 - 08:46 AM.
Posted 10 August 2009 - 09:15 AM
Edited by jaydee, 10 August 2009 - 09:15 AM.
Posted 10 August 2009 - 10:57 AM
i got a decent donor engine that im going to use, that way i can do it slowly and get everything right.
Edited by blacktulip, 10 August 2009 - 10:59 AM.
Posted 10 August 2009 - 11:14 AM
I have a 998 with mild port/cam and a weber, extractors and big exhaust, it goes well, and is fun.
I also have a 970s motor - bored to 999, super sprint cam, high lift rockers etc - that needs a rebuild. I am definately going to sort this out and have a screamer motor rather than get a 1275 like everyone else.
Posted 10 August 2009 - 11:16 AM
Although I now have a 1380, and I realy miss the 998's economy.
Posted 10 August 2009 - 11:18 AM
-1061cc A+ 11Stud Pocketed Block,
-Prepared By Classic & Modern
- +.80 Mega Type Flat Top MSC Pistons
- Weber 40 Jetted To Suit By MED, Top Mount Throttle Linkage
- ITG 'DCR' S/S Air Filter
- 3.75' Maniflow Manifold
- 12G1805,Swiftune ex Mini7 'FULL RACE' Spec Head
- 37x31 Rimflow Valves, 30* Seats, Bronze Guides,
180lb DV Springs, Steel Retainers, Pushrod Holes Sleeved,
14.0cc In Head, Huge Ports, Block Refaced, 12.9:1 C/R
- Swiftune SW10 Camshaft
- Swiftune Alloy Duplex
- 1.3:1 MiniSport Roller Tip Rockers
- Maniflow LCB & 1.75 single box
- MED RACE Spec Leccy Dizzy 286+, No Vac, Lightend Dizzy Dog
- MED Lightend Rods
- MED Wedged & Backdrilled Crank, Ground +0.10' 0.10'
- ARP Rod Bolts + ARP 11 Stud Head Bolt Kit
- Lucas Sports Coil + Lumenition Leads
- VP2 Oversized Competition Main & Big-end Bearings
- Swiftune Race Lightend Followers
- Steel Centre Main Strap
- Leccy Fuel Pump + Fuel Regulator
- Millers CTV 20W50 Semi-Synthetic Oil (currently miniral)
Clutch;
- M/S Pre-Engaged Ultralight Flywheel
- MED Lightend Backplate
- AP Orange Diaphram
- AP Rally/Race Friction Plate
- Whole Rotating Assembly Dynamicly Balanced By Classic & Modern
- Pistons, Rods, Crank, Clutch Assembly, Damper.
Gearbox;
- Rebuilt by Heathrow Transmissions
- MiniSpares 4Sync SC/CR Clubman Gearset
- MiniSpares X-Pin Diff
- 3.64 Final Drive
- Centre Oil Pickup
- Paul Wigginton Alloy Windage Tray
- KAD Quickshift
Edited by Racer_Pete, 10 August 2009 - 11:20 AM.
Posted 10 August 2009 - 11:21 AM
(wait till I get my supercharger!!)
(maybe then I'll get rid of the drums on the front!!)
