Points Keep Closing?
Posted 09 August 2009 - 11:18 AM
Please give your topic a title that quickly describes your problem. Just putting 'Help my Mini doesn't work' is useless to anyone trying to help.
mini city e
1985
998cc
hi all i'm having some trouble with the points on my mini, the points seem to close on their own
been to a mechanic who set it up worked perfect for a few miles then all of a sudden spluttering and loss of power.
back to the mechanic who traced the fault to the points not opening, they had closed somehow?
new points and new condenser and points set again,
a day in the mini and again coughing and spluttering, just checked the points and again they're closed????
the screw holding the points are tight so i cant see why there closing???
has anyone any idea whats causing this?
any help greatly appreciated
arwel.
Posted 09 August 2009 - 11:30 AM
Anyway, even though the screw is tight does everything work correctly? I had a problem a while back that the screw was fouling on the backplate of the dizzy and causing the vac advance to not work as well as letting the points slip. Which was fun to figure out after 3 weeks.
Another idea, just bend the arm on the points to get more spring back.
Final idea, if nothing else works (search first mind) is to change to electronic points. Company called MM 4x4 sells electronic points for the lucas 45D, I'm going with you have a 59D.
I've heard some people fitted them via some filing and they worked, but I have yet to make it work, so caution is advicesed on the "I will make it work" approach.
http://www.mm-4x4.co...-kit-2720-p.asp
Posted 09 August 2009 - 11:47 AM
Well, do a search because I'm fairly sure this has been covered a fair few times.
hi there thanks for the reply, i did try a search before posting but i couldnt find anything i will try again, bending the spring will not work i dont think as the points move away from the square rotating arm and this causes the points not to open as the points plastic arm are'nt in contact with the rotating squae drive anymore hope this makes sense
Posted 09 August 2009 - 12:15 PM
Posted 09 August 2009 - 02:59 PM
Also, only buy quality points. There have been problems reported on many U.S. boards about premature points heel wear that was more or less traced to Asian import parts. I don't know what to suggest for quality points in Europe. Over here we have a few vendors who have started having parts made to their spec. In the U.K. I know that one such vendor is called something like "Rare Bits for Classics" or something similar. However, I think their distributor parts are aimed at the 25D and 45D series.
Posted 10 August 2009 - 10:01 AM
i do fancy fitting the electronic ignition but i need to figure out what dizzy i have also need to find out whats happening in my dizzy before going forward and fitting the electronic ignition.
Posted 10 August 2009 - 10:04 AM
Posted 10 August 2009 - 10:15 AM
The 59 is only slightly different (it has wiper points) to the 45 and many bits, including the points, are interchangeable.
It could also be someone's lost the fixing screw 'n botched with the wrong thread.
