Taking Off The Rockers
2 replies to this topic
#1 blacktulip
blacktulip
  • 6,224 posts
Posted 09 August 2009 - 10:58 AM
Model:998cc mini 1000
Year:1971
i think my rocker tips are pitted as i cant seem to stop the noisey tappets even theough i have set them meticulously at .012". the only thing i can think of is that the tips are pitted making the valve sit in the pit, giving a wrong reading. if i was to take the rockers off, will i upset the head gasket?
#2 Ethel
  • 25,922 posts
Posted 09 August 2009 - 12:02 PM
If you undo the head studs, yes.
You can wind out all the tappet screws, then slide the rocker shaft through the rockers and posts to release them. You might even get a good enough look at the pads by just winding the screws as far as possible.
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 09 August 2009 - 01:24 PM
As above - DO NOT loosen the head nuts - just take the rockers out and stone the ends flat. Simples !
