Had A Little Bit Of A Scare Today
52 replies to this topic
#31 Ethel
  • 25,915 posts
Posted 05 August 2009 - 10:52 PM
If the disc broke up it could have taken an almighty whack, you would expect some evidence of where it was hit though.
I'd also have a close look at the swivel hub caliper mounting lugs and check everything runs true before committing it back to the road.
#32 newdawn1st
newdawn1st
  • 1,268 posts
  • Local Club: Fylde Mini Club
Posted 05 August 2009 - 10:58 PM
Wow, Lucky there lad. I would of thought that to be a faulty disc, not an informed person but I wouldn't expect a failure like that from excessive heat, unless it was v hot then rapidly cooled. MRA Minis seems someone on here who might be able to give some possible explanation(s) for it though.
Again Glad your OK and was sensible in getting it home.
#33 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 05 August 2009 - 11:03 PM
Yes that's another worry, Im a little worried the swivel hub is a little damaged where the caliper mounts, because something has realy taken a hit there. I also forgot too mention the alloy has a few gauge marks in it. This just seems too be cosmetic though. Realy gutted about the wing though, something realy hit that hard. I'll take a few pics for you lot tomorrow. Can I just say, when I went to pick up the pieces of disc from the road so it didn't damage any other cars, the disc was boiling hot, my mate picked it up and now has blisters on his hand, I poored water over it so I could put it in the boot and the water boiled.
Ben
#34 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 05 August 2009 - 11:38 PM
thats the same part of the caliper that sheared on mine see not just me >_<
#35 Bec
Bec
  • 5,900 posts
Posted 05 August 2009 - 11:48 PM
I'm so sorry to hear what's happened, but you managed to keep a cool head and stayed safe.
It's such a shame but minis can be fixed, at least you are ok >_<
#36 mrslaphead
mrslaphead
  • 362 posts
Posted 06 August 2009 - 12:02 AM
Apologies if Im wrong but didnt you carry on driving to your mates garage , which was what got you the most abuse.
This fella pushed his car home.
Who knows sean maybe in a mixed up way your incident did some good after all.
They probably only pushed it because they remembered the sh*t you got.
Stops - Future - Madness ?
#37 mini_mad69
mini_mad69
  • 5,417 posts
Posted 06 August 2009 - 12:22 AM
No, I pushed it because It was the sensible thing too do. If I didnt want to get shunned by a load of people on the internet I wouldn't have told you if I had driven it.
If sean had pushed his, he wouldn't have been so well known as he is now. We all make mistakes but come on who would drive a car with only 1 front brake?
Oh and it's his birthday so be nice too him. :thumbsup:
Ben
Edited by mini_mad69, 06 August 2009 - 12:23 AM.
#38 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 06 August 2009 - 12:43 AM
lucky thing you didnt push the calliper pistons out n ended up leaking fluid! otherwise would have had no brakes at all!
#39 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 06 August 2009 - 06:59 AM
Were the pads still about, and are the retaining pins still in the caliper?
I had a kinda similar failure on my mini years ago. Loud bang when brakign for a roundabout, and much less braking going on. Somehow I broke and lost a pad, the piston then hit the disk, and snapped the disc from the rotor/flange, this jammed the piston over, ruining the caliper, and leaking fluid.
mini_Mad69;
I'd go with replacing the hub and caliper, and checking the balljoints and track rod ends over.
Both discs, obviously, and new pads and retaining pins on the front.
Most of all though, I'm glad you managed to keep it under control and brought it to a halt!
Dave
#40 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 06 August 2009 - 08:00 AM
They look older than a month they also look blue >_<
#41 leaky
leaky
  • 6,890 posts
Posted 06 August 2009 - 08:46 AM
Holy crap. Atleast your ok. As said those disks look alot more then a month old. I would go and get some new ones on both sides and from a diffrent place to where you get them from.
#42 mini_mad69
mini_mad69
  • 5,417 posts
Just ordered a set of unipart pads and discs, and i've got hold of a caliper aswell.
Ben
#43 black jack1275
black jack1275
  • 276 posts
Posted 06 August 2009 - 09:43 AM
Glad to hear your OK
This might help explain what happened to the disc http://www.juratek.c...pport-discs.php
Edited by black jack1275, 22 December 2014 - 07:56 PM.
#44 Danny_California
Danny_California
  • 1,263 posts
Posted 06 August 2009 - 09:57 AM
Ooof gutted to hear about this dude, could have been soooo much worse though, imagine if it had happened as you were entering the roundabout >_<
You're ok is that main thing though, sure the dent can be smoothed over no problems, and if I were you I'd be shouting down the phone at whoever sold me those discs!
#45 mini_mad69
mini_mad69
  • 5,417 posts
Posted 06 August 2009 - 10:58 AM
Ok, well I was entering the roundabout, braking hard for it.
The discs are blue on both sides, so they have overheated, which I assume caused it too break. They wern't cracked on monday when I took the wheel off too screw the earth back on the aux fan.
Ben
Edit: Is this an acceptable way of breaking in new brakes. click here
Edited by mini_mad69, 06 August 2009 - 11:05 AM.
