Had A Little Bit Of A Scare Today
52 replies to this topic
#16 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 05 August 2009 - 09:52 PM
Well the discs were around 1 month old, and done around 500 miles, so should get away with buying the one disc.
Where did you get the disc from?
Ahh good point, I don't want the other too do the same. I can't remember where I got them from, I think it was at a show a while ago and fitted them around a month ago.
Im not sure what broke first though, the disc or the caliper.
Ben
#17 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Thats really SFM'ed up!
Glad your ok, could of been worse, really wierd though!
#18 Jackman
Jackman
  • 4,053 posts
Posted 05 August 2009 - 10:00 PM
Replace both discs, get some proper ones from minispares or minisport.
If one did it there is a good chance the other will too.
#19 mini_mad69
mini_mad69
  • 5,417 posts
Posted 05 August 2009 - 10:03 PM
Oke doke, makes sense anyway.
Got a new brake caliper lined up aswell. I'll get a new set of pads aswell.
Im not too bothered about the mechanics of it because they can be fixed easily, IM gutted about the massive dent in my wing!!!!!!!! >_<
Ben
#20 mini_mad69
mini_mad69
  • 5,417 posts
Posted 05 August 2009 - 10:05 PM
No no, I just remembered, those discs came from minispares a little while ago when they had a deal on giving pads aswell.
#21 Jackman
Jackman
  • 4,053 posts
Posted 05 August 2009 - 10:08 PM
Well get on the phone tomorrow and give them a proper telling to. Id be worried that there could be other minis on those discs.
#22 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 05 August 2009 - 10:09 PM
Basically whatever you replaced at the time needs to be replaced again, be very sure when you mention where you got them from, you need to be sure?
#23 mymini007
mymini007
  • 2,046 posts
Send em back, get a refund and some free discs for emotional stress or somthing like that. Glad you are OK
#24 mars red mike
mars red mike
  • 1,500 posts
Posted 05 August 2009 - 10:10 PM
There looks to be some scoring on that disc and it looks like it has overheated too in the past.
#25 mini_mad69
mini_mad69
  • 5,417 posts
Posted 05 August 2009 - 10:14 PM
Nope definatly off minispares, came with pads aswell. They realy stopped the car well.
Yes, they have got hot before, i've had brake fade with them. Hmmmm I did buy them a good time ago maybe 18 months now. SO won't realy be able to arue it. Only fitted around a month ago though.
Edited by mini_mad69, 05 August 2009 - 10:17 PM.
#26 Kam
Kam
  • 4,140 posts
Posted 05 August 2009 - 10:16 PM
Where were they kept? In direct sunlight?
Only joshing >_<
#27 Ethel
  • 25,915 posts
Posted 05 August 2009 - 10:25 PM
Did you bed them in? If they've only been on a month they've done some heavy braking to get that colour. Someone with some technical metallurgy know-how may be able to tell which bit killed the other by looking at the broken bits. The manufacturer ought to be interested.
#28 jaydee
jaydee
  • 8,565 posts
Posted 05 August 2009 - 10:33 PM
Glad you're ok, thats a curse on that roundabout!!
Anyway..
Cant be that groved just after 500 miles, those are cheap chinese discs, are made of chocolate. Get the proper quality discs from minispares, they arent expensive too, difference is about 10 pounds..
But its still strange it got broken that way, i'd replace the caliper aswell and carefully inspect the hub for any damage.
#29 mini_mad69
mini_mad69
  • 5,417 posts
Posted 05 August 2009 - 10:35 PM
It would appear the disc came apart, move away from the central point, cam around and hit the caliper. Im only guessing here though. But this is what appeards to have happened.
Now bedding in, teach me about this, I drove around slowly with a small amount of brake preasure.
I never realy thought much about it.
Ben
#30 mini_mad69
mini_mad69
  • 5,417 posts
Posted 05 August 2009 - 10:37 PM
Anyway..
I have to replace the caliper, the mount has snapped on it.
Im just as confused as too why it broke.
Ben
