Manifold Gasket
9 replies to this topic
#1 jmetal88
jmetal88
  • 289 posts
  • Local Club: okMini
Posted 03 August 2009 - 10:11 PM
I hate to have to ask this, but I went back about 5 pages in search results and couldn't find any posts about it.
When fitting a new manifold gasket, which way around does it go on? I just received one from Moss Motors, one side is metallic and slightly raised, and the other side is grey and mostly flat. Which side goes toward the head and which side goes toward the manifold, or does it matter?
#2 mk1leg
mk1leg
  • 9,343 posts
Posted 03 August 2009 - 10:26 PM
shiny side faces head ............ :errr:
#3 Turbo Phil
Turbo Phil
  • 2,426 posts
Grey side to the head.
#4 jmetal88
jmetal88
  • 289 posts
Posted 03 August 2009 - 10:27 PM
Wow, conflicting answers already! :errr:
#5 Ethel
  • 25,919 posts
Posted 03 August 2009 - 10:33 PM
doesn't matter :genius:
There, you've got the full set now :errr:
#6 mrslaphead
mrslaphead
  • 362 posts
Posted 03 August 2009 - 11:33 PM
This is from minispares description for an injection exhaust manifold
special reinforced gasket for injection cars-has metal inserts on exhaust ports plus a metal back on the manifold side which makes surface easier to clean when replacing.
#7 jmetal88
jmetal88
  • 289 posts
Posted 03 August 2009 - 11:41 PM
Alright, thanks for that! I was temped to put the metal towards the head since it seems that would be the hotter surface.
#8 Pauly
Pauly
  • 4,213 posts
Posted 04 August 2009 - 07:20 AM
If its a injection gasket then it should be stamped 'manifold side' on the gasket, but as a general rule the shiny side faces the manifold.
Paul.
#9 Ethel
  • 25,919 posts
Posted 04 August 2009 - 09:29 AM
I'd expect the manifold to be hotter, the head is thicker and is cooled (there are also alloy heads about but alloy exhaust manifolds are few and far between).
I never knew injection cars had a different gasket - anyone used it with forced injection, is the all metal turbo gasket still king?
#10 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 04 August 2009 - 04:00 PM
The proper injection gasket has the metal fire ring around the ex ports like the Turbo one & is a cheaper & suitable alternative.
