Hi, I own a '99 Mini Cooper Sport, which I run as a second car.
Can anyone recommend a strong battery, as it's often left unused
for a week or two, and the standard alarm etc, seems to drain the
current battery quickly. Thanks all.
Can Anyone Recommend A Good Battery For A Late Mini Mpi ?
SolarRedSport
, Jul 29 2009 06:17 PM
4 replies to this topic
Posted 29 July 2009 - 06:17 PM
Posted 29 July 2009 - 06:23 PM
anything thats bigger than the current one will be better. typical ones used are 063, and 075 batteries (most places recognise these numbers, even halfords!) sometimes those numbers might be prefixed with some letters, i.e. a halfords battery might be HB063. Also resonably cheap, and easy to get as a lot of cars use those. I have an 063, and ive not used the mini for about 6 weeks - it fired up first time today.
alternatively if you have lots of money to burn, is to get hold of an Optima Yellow or Red top battery, but these can be a few hundred pounds, they are extrememly powerful, designed to run huge stereo systems so have a very long life compared to a normal battery.
Posted 30 July 2009 - 07:22 AM
i spent some time looking into better batterys for my MPI and found this Visit My Website since installing it i have had no problems starting even if left for couple of weeks and it also handles the drain from my audio equipment very well and good price too
Posted 30 July 2009 - 08:06 AM
I believe there is a Pug ( possibly from a 306 TD ? ) which is a recommended upgrade, but in reality, if you're going to be leaving your car for an extended period of time, it's just as easy to disconnect the battery... or you can get solar powered trickle chargers which will keep it topped up cheap enough...
http://www.maplin.co...?moduleno=47902
Posted 30 July 2009 - 05:05 PM
Thanks for all your advice, it's much appreciated.
