Whats The Best Seam Sealer?
20 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 27 July 2009 - 09:18 PM
Hi
I am wondering, what is the best or recommended seam sealer, which when applied, can penetrate the seams without a gooey mess on the outside? One of the things I need to do is seam seal the door step/sill flanges, and I need good sealant penetration here without lots of mess on the outside.
I have coated the bare metal areas first with U-POL Self etch primer, and then want to seal on top of the etched joints.
I already have some seam sealer (U-POL red strip). Is this any good, or should I change it? Also, is is recommended to use seam sealer in tube or brush on form?
#2 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 27 July 2009 - 09:30 PM
I was wondering if Pinkgrip would work. Because im a cheapskate, i'll try it tomorrow and see it i can paint over it.
Features:
- for internal use
- overpaintable when cured
- food safe
- gap filling
- quick drying / curing
- solvent based
:thumbsup: Sorted
#3 Mr Joshua
Mr Joshua
  • 378 posts
  • Local Club: Rebels mini club
Posted 28 July 2009 - 10:27 AM
Dynatrol AV9.
#4 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 28 July 2009 - 11:49 AM
Hi, if you also mask up the edges of the seam that needs sealing with some thick masking tape,.. you can apply it nice and thick so that you get a good seal and can spread it smooth with your finger without getting any messy edges.
once removed (straight after you've applied the sealer and smoothed it down) you'll have a nice neat finish.
Make sure it's completely cured before shooting the primer over it or the edges will lift.
#5 kirk
kirk
  • 143 posts
Posted 28 July 2009 - 11:56 AM
tiger seal in a tube
easy to apply and over paintable
best i have found
#6 minitomo
minitomo
    Starting My Mini Up
  • 2 posts
Posted 28 July 2009 - 12:26 PM
me second on that tiger seal is the stuff you need. its about £9 a tube. i work for london transport and half the busses are stuck together with that.
#7 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 28 July 2009 - 01:22 PM
you can tell when you're in them :thumbsup:
#8 mk=john
mk=john
  • 1,167 posts
Posted 28 July 2009 - 08:02 PM
you can tell when you're in them :P
Tiger seal it is then..also from a tube i think it will go on much neater
#9 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 28 July 2009 - 10:01 PM
yes the tubes are much easier to use and give a nice clean bead - thought you have to push bloody hard to get it out,..
all the best :P
#10 mk=john
mk=john
  • 1,167 posts
Posted 30 July 2009 - 07:40 PM
best i have found
Hi. I have just received my Tiger seal in the post, and I notice that they are sealed in a metal tube. Can i use this in an adhesive gun (same one you use for bathroom sealants etc). i know it sounds like a silly question, but i notice the end of the tiger tubes are just flat metal, and i cannot see any plunger. Is this some kind of seal on the end that needs to be broken??
Edited by mk=john, 30 July 2009 - 07:40 PM.
#11 kirk
kirk
  • 143 posts
Posted 30 July 2009 - 07:49 PM
yes mate break the tin foil end open and peel off
then it will fit and use adhesive gun
then smooth it out with your finger
makes a nice job and is strong
Edited by kirk, 30 July 2009 - 07:50 PM.
#12 mk=john
mk=john
  • 1,167 posts
Posted 30 July 2009 - 08:00 PM
Hi Kirk
I mean on the bottom end, it looks like its just covered over. Also, when i shake it, it seems to have sand in there!
#13 kirk
kirk
  • 143 posts
Posted 30 July 2009 - 08:04 PM
yes pearce that and rip it off mate
do it now you will see the plunger in the end then once removed
Edited by kirk, 30 July 2009 - 08:05 PM.
#14 jack_marshall
jack_marshall
  • 2,540 posts
Posted 30 July 2009 - 08:08 PM
:) Tiger seal.
#15 mountainmole
mountainmole
    Starting My Mini Up
  • 4 posts
Posted 31 July 2009 - 02:58 PM
Probably a stupid question.
zinc prime then seam seal?
