Gsxr1000 K6
6 replies to this topic
#1 bigjobz
bigjobz
    Starting My Mini Up
  • 2 posts
Posted 24 July 2009 - 08:44 AM
hi guys
am tring to wire a gsxr1000 06 model
when i bought it i the wiring loom and diagram so i took out all i did not need but now cant get any spark,,,,i have the tip over pluged in,,have been told to put a 100 ohm resister between wires orange and orange and yellow,,is this right also what wattage do i get the resister
thanks
steve
#2 chunkytfg
chunkytfg
  • 116 posts
Posted 24 July 2009 - 11:31 AM
Edited by chunkytfg, 24 July 2009 - 11:36 AM.
#3 chunkytfg
chunkytfg
  • 116 posts
Posted 24 July 2009 - 11:32 AM
hi guys
thanks
steve
To serve what purpose?
Sound like the trick used when you remove the ingition barrel on race bikes? Is this bike for racing with?
What is it you are actually trying to do with the wiring loom?
#4 chunkytfg
chunkytfg
  • 116 posts
Posted 24 July 2009 - 11:41 AM
sorry not 100% on the 4cylinder engines but have you had any work carried out lately.
If my assumption of race bike is correct are you trying to run it 'total loss' if so have you have the flywheel machined?
No spark at all would indicate coil pack issues, ht lead issues etc. as in the bike doesnt know when to spark or cant spark.
Are you getting a good ground with the plug when you check?
Are you 100% certain every single connector is connected? I used to alwasy miss one when i was rebuilding my race bike.
The tilt sensor you say it is connected but it is lying the right way up(silly question i know!)?
#5 bigjobz
bigjobz
    Starting My Mini Up
  • 2 posts
Posted 24 July 2009 - 11:45 AM
hi guys
thanks
steve
hi its going in a speedway sidecar so i need the basic wiring to run it
thanks
steve
#6 chunkytfg
chunkytfg
  • 116 posts
Posted 24 July 2009 - 11:53 AM
hi guys
thanks
steve
thanks
steve
a gsxr 1000 lump in a speedway sidecar would be awesome!!!
So my asumption of a 'race loom' is correct.
#7 chunkytfg
chunkytfg
  • 116 posts
Posted 24 July 2009 - 12:20 PM
Right text steve Jordan from steve Jordan motorcycles about the resistor thing and bypassing the ignition barrel and this was his response
[quote]Can't do that imobiliser in ignition need kit loom to remove or keep chip and aerial on bike not easy to do [\quote]
