Modded Minis And The New Law
391 replies to this topic
#301 dsgoody
dsgoody
  • 519 posts
  • Local Club: Gert Lush Minis
Posted 22 July 2009 - 12:37 PM
Although its not the death of all minis, it does seem like it would kill off alot of popular mods. I mean the amount of people who already have flipfronts and engine conversions? What are they meant to do, convert back to standard or have their V5 seized until they save enough money for IVA mods and costs...
This is a question that would need to be answered, all these people who have successfully run their cars with modifications that would result in a IVA for many years would be forced to spend money on something, that when they were building the car was non-existent.
Many questions have been asked about Webber boxes, but I assume Turbo boxes would result in an IVA since they cut into the main portion of the bulkhead? Also, are these laws currently being enforced (and if not, when)?
#302 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 22 July 2009 - 12:41 PM
forgive me if im wrong but this seems like speculation
why worry about tomorow when its hard enough today to have any money or even a car
#303 CMcB
CMcB
  • 999 posts
Posted 22 July 2009 - 01:55 PM
Firstly, this has all been law for 20 odd years, just that no one has enforced it or adhered to it. Mot testers will be retrained to inform the DVLA of obvious mods and deviations from Type approval.
The answer is yes, the registration will be revoked and you will have to pay for the IVA plus the costs of changing the car so it will pass an IVA. The basic point is, dont modify your car so much that it will require an IVA. For some it may be too late (shortys, roof chops etc).
Weber boxes, as mentioned before I am awaiting confirmation, please read my post on the last page.
SFM - this is not speculation, and it is not tomorrow, it IS today - as Garrett has pointed out several times.
#304 CMcB
CMcB
  • 999 posts
Posted 22 July 2009 - 02:16 PM
My final questions have been answered and so this will hopefully clear up a lot of 'what is or isnt allowed'.
My questions are in bold
"Approvals
Testing and Support Services (TaSS)
VOSA,
Ellipse,
Padley Road,
Swansea,
SA1 8AN.
Good afternoon Craig ,
Thank you for your further enquiry regarding this matter. As previously, I
have answered your questions below in the order they have asked in blue
text, to aid clarity.
I do hope this additional information is helpful, but should you have any
further questions, please do not hesitate to get in touch.
Best regards,
Mark
Mark Vickers Eng Tech MSOE MIRTE
Technical Officer
Approvals
Passenger Cars & Light Goods Vehicles
Vehicle & Operator Services Agency
Department for Transport.
++44 1792 454256 - Tel
++44 1792 463581 - Fax
Craig McBeth
<Craig.McBeth@fut
urenet.com> To
"[email protected]"
21/07/2009 11:22 <[email protected]>
cc
Subject
Additional Mini query
Hi Mark
Following our chat I have some other questions which are hopefully a little
clearer and more pertinent than the previous ones sent to the DVLA. If you
could be kind enough to answer these too. I am sorry if we are covering the
same issue several times. The email to the DVLA was mainly with regards to
the points system and asking what would classify as a mod and thus reduce
the points available for totting up, under the points scheme. Hopefully
upon receipt of your response this should answer all my questions.
I am under the impression that the points system is used to decide whether
a car needs an IVA or not. Is this correct, or can the DVLA inspector just
decide a car is radically modified and send for an IVA? Or are there
certain ‘triggers’ that automatically need an IVA?
The points system does not necessarily decide if a vehicle requires an IVA, but if it is used,
then it will. An automatic IVA is invoked in circumstances such as a major
chassis or monocoque alteration, the vehicle identity is lost (due to
missing or altered chassis number perhaps) or the vehicle comprises of all
new parts (such as a second hand body shell or spaceframe rebuild).
1. What are the implications of swapping the A-Series engine for something
like a VTEC or bike engine (fitted to the front) with a custom or modified
subframe (ignoring any suspension or brake mods and assuming no body mods)?
This could only be decided by an inspection of the vehicle. An engine
change of this type could not be done in isolation (unless you intend to
drive a potentially unsafe vehicle !) so it is not really possible to give
an accurate assessment. However, if only the engine had been changed, then
the current DVLA guidelines would suggest that this would not require an
IVA.
1a. If a 998cc R1 bike engine replaced a 998cc Mini A-Series unit, fitted
to a modified subframe in the front end but with no body mods, no brake
mods, no suspension mods. In theory, the logbook information would match
up, both engines are 998cc, and the body is unmodified. How would this fare
in your eyes? I suspect it would be up to the MoT tester to spot this, but
how would they know if the DVLA had already been informed or not, as the
info would already be correct on the logbook and there is no other
provision for stating otherwise.
Your are right that there is no way the authorities would be aware of this modification, other than the change to
the engine number (required to be notified to the DVLA). As stated above,
this should not be an issue causing an IVA.
2. Would adjusting the bulkhead (to perhaps accommodate a carburettor box)
be seen as a mod to the bodyshell/chassis. Is this likely to be acceptable?
Again, a pragmatic approach would be taken. If a minor modification had
been made then this would not be a concern, however, removing the scuttle
panel complete might cause an issue. The current practice of inserting a
thicker plate would be acceptable, but removing the scuttle plate would not
as this is part of the integral strengthening of the monocoque.
3. Can you clarify which of the following mods are likely to be considered
‘crossing the line in to IVA territory’?
Tubbing arches Not an issue in isolation
Fitting coil overs instead of standard dampers/shocks Not an issue in
isolation
Deseaming the Mini Not an issue in isolation
Flip fronts/removable front end Not able to give a definitive answer
due to the non-standard nature of the conversion. Could be an issue.
Roof chop Would definitely trigger an IVA Inspection
Aftermarket sunroof Only if a full roof type, mainstream aftermarket
units should be OK
Cabriolet conversion Would definitely trigger an IVA Inspection
Removing the inner wings (non structural) Not an issue in isolation
4. At a DVLA inspection, if the inspector deemed the vehicle did require an
IVA because it had ‘crossed the line’ of acceptable mods, would the owner
be given the chance to remove the mods and put back to acceptable items
before registration would be revoked?
From experience, I would suggest that once the vehicle had been inspected, there is no way back. However, if the
vehicle is inspected and found to be "as original " no further action would
be taken.
5. Are the modfications, such as those listed below, likely to be deemed
acceptable by the DVLA?
Adjustable ride height (hi-los) Likely to be acceptable in isolation
Adjustable suspension arms (adjusting camber and caster) Likely to be
Polycarb/perspex windows Likely to be acceptable in isolation
Internal gear linkage Likely to be acceptable in isolation
Debumpering (no sharp edges) Likely to be acceptable in isolation if
carried out correctly (no grinding of structural welds etc)
Uprated brakes (four/six pot)/rear disc brake conversion Possibly
acceptable in isolation, but as this would normally be as part of a package
of modifications, could be problematic.
Shortened dampers (as manufactured) Likely to be acceptable in
isolation
Bodykits Possibly acceptable in isolation, assuming the changes were
not structural, but as this would normally be as part of a package of
Fitting a rollcage (bolted or welded) Likely to be acceptable in
isolation.
It is worth mentioning once again that it is only the vehicles that have
major modifications that are the target of this general tightening up of
the rules. Continual complaints from the general public about the "boy
racer" fraternity and the unacceptably high death rate among young and
inexperienced drivers have been the driving force for the increased
scrutiny of this issue, but it is not meant to disadvantage the vast
majority of law abiding citizens who merely wish to enhance the enjoyment
of their vehicles. While it is a very complex area of legislation, a
pragmatic and relaxed approach is being used to assess vehicles currently,
in order to educate, rather than mandate change.
Can I just say a BIG thank you to Mark at VOSA for being ever so helpful. I know I can be annoying at the best of times and he has just shown that there are some really good apples working in the motor section of government organisations.
I think I have covered most common enquiries, for any further specific questions about your own personal project, please contact Mark yourself who, as he has already shown, will be very willing to help clarify the legislation. 01792 454256, [email protected]
Edited by CMcB, 22 July 2009 - 02:21 PM.
#305 rustandoil
rustandoil
  • 317 posts
Posted 22 July 2009 - 02:48 PM
^^^^ interesting stuff !!
I suppose "significant changes to the monocoque" covers z-cars type conversions?
#306 Geehawk
Geehawk
  • 500 posts
Posted 22 July 2009 - 02:50 PM
So pretty much anything would be an issue as nobody does the sort of mods that are "accepatble in isolation", in isolation do they :P
#307 ferrit
ferrit
  • 716 posts
  • Local Club: n/a
Posted 22 July 2009 - 03:33 PM
How bizzare that its deemed acceptable to install and engine from a motorbike (998cc) which would require some major reworking to the front subframe but a flipfront /removable front that doesnt affect engine mountings and relativley minor alteration to the front sub frame mounting only , could be a problem.
#308 garrett3
garrett3
  • 1,412 posts
Posted 22 July 2009 - 03:57 PM
Thats not really what he is saying.. if you was to tell the DVLA about the engine change then the points on that alone would not require a IVA BUT as per normal conversions the frame and suspension is modded too giving cause for concern.
Can you see what I'm getting at here?? :P
#309 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 22 July 2009 - 03:59 PM
Thankyou so much Craig for looking into this for EVERYONES benefit :P
Top bloke :( .
#310 garrett3
garrett3
  • 1,412 posts
Posted 22 July 2009 - 04:01 PM
Yes it does... Z CARS can give you guidance on getting a home converted (kit) car through a B IVA.
Z CARS have even regsieterd cars on 08/09 registrations and have made the cars comply to the old SVA so I'm sure the N IVA wont worry them either.
Gonna be pricey for alot of the Z cars owners out there but lets face it if you can afford one then you should be able to afford the compliance test costs?
#311 garrett3
garrett3
  • 1,412 posts
Posted 22 July 2009 - 04:02 PM
Thankyou so much Craig for looking into this for EVERYONES benefit :(
Top bloke :cry: .
Yup cheers craig :P
#312 CMcB
CMcB
  • 999 posts
Posted 22 July 2009 - 04:17 PM
Top bloke :( .
Thanks, but the real thanks should go to Garrett for bringing this to everyone's attention, despite the abuse he received originally. I have simply acted as a mediator to get some answers for you all.
#313 CharlieBrown
CharlieBrown
  • 6,587 posts
Posted 22 July 2009 - 04:21 PM
I belive its because a flip front changes the crash safty of the car, thats my understanding anyway.
#314 HARBER07
HARBER07
  • 4,498 posts
Posted 22 July 2009 - 04:26 PM
Shaun should know im extremely grateful for him bringing this up anyways, from the PM i sent him :P .
#315 rustandoil
rustandoil
  • 317 posts
Posted 22 July 2009 - 05:12 PM
Fair comment :)
