Engine Stall On Cornering
Posted 13 July 2009 - 06:53 PM
when i release the throttle going downhill then steadily braking before turning GENTLY into a driveway for example..the engine will cut out..i know the standard SU is famous for this problem (sometimes)but it cant happen on ALL mini's...????
Any suggestions will be helpful but i would like to keep the original HS4 1 1/2 carb.....cheers..!!
Posted 13 July 2009 - 07:08 PM
Hello all..please can anybody advise me how to cure this problem i have with my 1275 GT (all standard)
Is there oil in the dashpot of the carb? this kept happening to me the other night. put some more 3 in 1 oil in the dash pot, all was fine.
Posted 13 July 2009 - 07:17 PM
Posted 13 July 2009 - 07:31 PM
I believe that this can happen when the engine oil level is low.
upon cornering, the oil can surge to one side ,resulting in a temporary drop in oil pressure.
It used to happen to me when i braked sharply at a roundabout for e.g.
Posted 13 July 2009 - 07:36 PM
Posted 13 July 2009 - 07:45 PM
Posted 13 July 2009 - 07:48 PM
Posted 13 July 2009 - 07:56 PM
Posted 13 July 2009 - 08:11 PM
Posted 14 July 2009 - 08:18 AM
Why would low oil cause you to Stall...low oil pressure isnt going to stall your engine, it might Sieze it, definitely wont stall it. I suppose if there is less oil then there is more fricition so becomes harder to turn over, but if thats the case, Definitely a rebuild called for!
this is actually a known issue with the original oil pickup pipe. It is situated to the right of the sump (as looking at the engine from drivers seat) and that means that if the oil is low when you turn a left hand corner the oil moves to the left of the sump due to centrifugal force and the pickup pipe is no longer submerged. this then causes a sudden drop in pressure that makes the engine stall. Most later and modified/ tuned engines have a central oil pickup fitted when the pipe bends round and under the gears to the middle fo the sump so that no matter which way the oil goes it is still submerged.
Yup...the rings are worn and the clutch is on its way out...the good news is that the mini is to be stripped to shell,dipped,welded primed and painted. engine to be rebuilt as the original leaded hesd is still on it...etc i just wanted to run it till the end of the show season...thanks for the info
When you rebuild it, fit a Central Oil Pickup Pipe and you'll not have this problem
Posted 14 July 2009 - 12:59 PM
Posted 14 July 2009 - 01:50 PM
Although there is a possibility that I am mistaken on the side the pickup is on! LOL
Posted 15 July 2009 - 10:27 PM
my next step is to investigate the needle and jet . are there standard sizes that fit straight in..or have they got to be ''profiled'' 1975 1275 GT
Posted 16 July 2009 - 07:38 AM
To try and diagnose your problem start the engine and leave it running. Have a good look at all the wiring and give it a good tug, check the fuel pipe and all the breather hoses. Pull on the carburetor to see if it or the manifold is loose. It's possible you have an air or vacuum leak and the jolting is moving something. Check the battery connections, earth straps, distributor, coil and HT leads. Just have a good poke while the thing is ticking over.
If that doesn't find the problem you may want to check that the float in the carburetor is a) floating and b) closing the valve correctly.
I'll be watching this topic with interest Sidders. Many years ago I had an MG Metro which would cut out on moderate to tight left hand corners. The thing would give no warning, it would just die but start immediately when the key was turned. I tried everything I could think of and spent ages trying to solve the problem but never did. The most annoying thing was that it was so predictable and repeatable and should therefore have been easy to diagnose.
Eventually, and much to my shame, I sold the thing after navigating potential purchasers on test drives that only happened to turn right. All I can say in my defence was that I was young then and had no money.
Good luck.
Edited by SolarB, 16 July 2009 - 09:40 AM.
