Been having some major issues with my mini, mostly with very bad hessitation before acceleration!
Before it was managable, but now the engine cuts out.
While slowing building up the revs suddenly smoke came out from where the air filter box attaches to the carbourettor (air filter box was off at this moment), then it was ok. but then it did it again (after about 5seconds) and the engine cut out. Wasn't a huge amount of smoke, but enough to know it definatly shouldn't be doing that.
Any of you guys and gals know what the problem could be??
EDIT:
OK, with a bit of research I think the white smoke is from the engine burning oil. So I think it's the piston rings or the valve seals.
Are there any checks to test these?
Edited by nicknicknick, 12 July 2009 - 01:40 PM.
