Mpi Oil
Posted 12 July 2009 - 08:34 AM
Posted 12 July 2009 - 08:43 AM
Posted 12 July 2009 - 08:51 AM
dont use synthetic get a good name brand or if using cheaper stuff do more freqent oil filter changes
Posted 12 July 2009 - 08:52 AM
Posted 12 July 2009 - 09:02 AM
10/40 isnt that for modern engines like said it is an a series at heart
mpi is a modern engine fuel injected ,cataliic converter etc
10/40 is want its designed to run and thats what the manul states
Edited by THE STIG, 12 July 2009 - 09:04 AM.
Posted 12 July 2009 - 09:04 AM
how's the hospital food or are you home yet?
Posted 12 July 2009 - 09:23 AM
search in this section turned up replies in earlier topics but cant paste was in the last month
is to due to older classic oils using aditives that can bugger up oxegen sensor and cat
Posted 12 July 2009 - 09:31 AM
PS - any nice looking nurses on your ward
Posted 13 July 2009 - 06:34 AM
Hi Stig,
Sorry, could you explain this statement? Whats in 20W50 thats not in 10W40 that would hurt the cat/ lambda? They are both "classic" oils due to being mineral, not semi etc; the reason i ask is i have just changed my oil to 20W50, after being on 10W40 for 3 years, on the recommendation that it would be better for the gearbox, as that hasn't changed when they introduced the Mpi (apart from the diffs). The only way oil could come in contact with the cat and lambda would be if the engine is burning excessive amounts? - thus, any type of oil could do the suggested damage? Please let me know your reasoning,
many thanks
Ryan
Edited by L400RAS, 13 July 2009 - 06:35 AM.
Posted 13 July 2009 - 08:03 AM
It doesn't actually matter what you use. It ain't gonna make the thing explode. But other people can be veeeeeery particular about what they want to put in their cars....
Posted 13 July 2009 - 08:22 AM
As your Oil goes inside the engine and lubricates the gubbins and then sits in your gearbox all night and that the internal gubbins are roughly the same as theyve allways been id go by what was used and recomended for the first 30 years of the Mini not the last 10
As Juju said your engine or gearbox isnt gunna go bang if you use 10w40 but what you will get is more leaks and i found the newer sooper dooper oil went dirtier quicker too
Boris as you probably all know is an Automatic and he was slipping out of gear etc with 10w40 (the supplying garage did that oil change not me) and now with good old Duckham Q 20w50 mineral he,s quieter,and smoother and changes up and down better
He still slips out of gear occasionally but nowhere near as much as he did
Deep down i believe the 10w40 which incidentally was synthetic (the garage thought they were doing us a favour
So id never put 10w40 in again and Boris is getting an exchange/rebuilt gearbox soon and nasty synthetic 10w40 will never pass its cogs!!
Just My Opinion based on experiences
Huggz
Jodie
Edited by Joloke08, 13 July 2009 - 08:24 AM.
Posted 13 July 2009 - 08:24 AM
Hi Stig,
many thanks
Ryan
as i said in the post ,classic oils, they tend to have addetives for higher milage engines which can be bad for lamda and cat
did not say all 20/50 oils you will have to read other post to see what others said
gearbox has nothing to do with it will run just as well on 10/40 all the numbers are is the heat range for the oil
all engines burn oil in nornal running may only be a tiny amount of vapour but it all goes down the exhhaust
the manual states 10/40 thats what they recommend
if you wnat to run something differant thats upto you does not chnge the fact they state 10/40
Posted 13 July 2009 - 11:59 PM
I posted elsewhere I just completed a 5,000 mile trip including at least 7-10 hours of constant operation at full throttle, and it used only 2 quarts. If I hadn't been running flat out, it probably would have used no more than 1 quart. Top-ups coincided with long periods of max throttle. I use 20/50.
Even the "classic" oil you can buy today has little similarity to motor oil produced in 1960. Oil techology has advanced enormously in the past 50 years. Even if I could get 10 gallons of the stuff out of a time machine I wouldn't use it.
The main differences between "classic" oils (made today) and oils for modern cars is in the additive package. Due to emissions, some of the additives used for older technology cars have been reduced. As mentioned, these additives can pollute the emissions control equipment. But O2 sensors and cat converters have been around for decades. Mini emissions tech dates from the 90's, so obviously oils meeting those standards are fine.
You can still get oils of all types (conventional and synthetic) with suitable additive formulations. The basestock (synthetic vs. conventional) has nothing to do with it.
Synthetic basestock have oil molecules that resist shearing and breakdown far better than conventional oil. Just what is needed in a engine-oil lubricated gearbox. My engine has at least 60,000 miles on it, and it doesn't leak any oil either, believe it or not! I fixed the rocker cover seal and one diff/driveshaft seal over 3 years, and it ceased leaking oil. Oil leaks are caused by leaky seals, not synthetic oils as many people claim.
The only claim I don't really follow (regarding synthetic) is I don't leave the oil in for 15,000 miles. I change it every 6,000. If I were using conventional oil, a 3,000 mile change is a must. I believe the synthetic after 6,000 miles is as least equal in stability to fresh conventional oil, but I want to flush out the metal shavings and swarf from the transmission. I don't know if there is any scientific backing behind this, but it makes me feel better.
Edited by bluedragon, 14 July 2009 - 12:01 AM.
Posted 16 July 2009 - 07:20 PM
Posted 31 July 2011 - 04:32 PM
Not my manual. I have a 1999 MPi with original books and it states 10W/30. Can scan the page if you like.
