Project: Mini Minus
313 replies to this topic
#256 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 27 June 2012 - 08:43 PM
Heres a few to keep you moist till I do a proper chronological udate :D
#257 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 27 June 2012 - 08:49 PM
Thats more like it. Looks good!
I can't tell what engine that is haha.....?
You make the subframe? Looks like it fits in nicely.
No clearance issues?
#258 HARBER07
HARBER07
  • 4,498 posts
Posted 27 June 2012 - 08:52 PM
C16XE - Vauxhall 1600 16V. Will be running CBR900 ITB's, Megasquirt ECU and a 50 shot of Nitrous for good measure. ~210bhp
Home made frame, way stronger and an Allspeed frame in my opinion, and a better design. No clearance issues whatsoever. It was basically a case of - it needs to fit, so I'll make it fit!. Shame I had to cut the front end off though, but its a million times more. practical. And after all - its now more of a race car than anything else.
Edited by HARBER07, 27 June 2012 - 08:53 PM.
#259 jonny f
jonny f
  • 1,485 posts
Posted 27 June 2012 - 08:58 PM
Should be great fun in a minus!
Could you not have just cut the inner wings out?
Fancy making another subframe? ;)
#260 HARBER07
HARBER07
  • 4,498 posts
Posted 27 June 2012 - 09:02 PM
Nope. The engine fitted fine, but the subframe wouldn't. It was a case of modify the front valance to allow the front subframe bar to slide up into the engine bay, or cut the lot of. In the long run i think it'll more than pay off though. At least it'll fit fine as opposed to most front ends lmao.
#261 jonny f
jonny f
  • 1,485 posts
Posted 27 June 2012 - 09:04 PM
Ahhh right i see it now. Hadn't thought of that!
#262 HARBER07
HARBER07
  • 4,498 posts
Posted 27 June 2012 - 09:05 PM
And as for the subframe - no lol. There isn't a lot i'd change on my frame, and the basic structure didn't take long. But there is about 25 gussets I welded in, which took forever!!. Then whats left of the standard frame I seam welded.
#263 HARBER07
HARBER07
  • 4,498 posts
Posted 27 June 2012 - 09:06 PM
Everything is stupidly tight, examples - lol
5mm - cambelt to bonnet
2mm - gearbox to tower front
4mm - gearbox to steering rack
etc..
#264 jonny f
jonny f
  • 1,485 posts
Posted 27 June 2012 - 09:09 PM
That is tight! Hope its solid mounted!
#265 HARBER07
HARBER07
  • 4,498 posts
Posted 27 June 2012 - 09:15 PM
Not quite, but nearly. It's on Landy V8 engine mounts, which are pretty hefty!. Engine movement has been accounted for in any case. There shouldn't be much with these mounts, and any hint of torque is likely to spin the wheels out of control!
#266 blue blood
blue blood
  • 806 posts
Posted 27 June 2012 - 10:24 PM
Finally some pictures its looking good :) I think once I have passed my SVA and my mini MPI unit goes pop i'll go vauxhall but and 8v 2.0L :ph34r:
Keep up the good work.
Regards Blue
#267 Burnard
Burnard
  • 3,350 posts
Posted 27 June 2012 - 10:33 PM
looking good dude.
What rad is that?
#268 HARBER07
HARBER07
  • 4,498 posts
Posted 27 June 2012 - 10:42 PM
A big block engine would be far too heavy for a Minus IMO. But it'd make things slightly easier going 8V!
Trying to keep as much as possible either Vauxhall, or universal stuff at the front end, to make stuff cheaper to replace and more modern. And to answer the actual question - '93-'00 Corsa/Tigra radiator. I believe its also standard fitment for this exact engine. When I get some proper pics up like on 16v, you'll see I had to stick a bend in it to clear the N/S headlight.
As always there's an exception - the alternator is a Denso from a Daihatsu, but it is fitted with the standard vauxhall pulley.
Edited by HARBER07, 27 June 2012 - 10:43 PM.
#269 Burnard
Burnard
  • 3,350 posts
Posted 28 June 2012 - 09:29 PM
Not bad though, looks like it would fit pretty damn well even with the vaux frame. Mine is a lil small really.
Where does the bottom hose come out?
#270 HARBER07
HARBER07
  • 4,498 posts
Posted 28 June 2012 - 09:39 PM
Check out 16v mate, loads more pics on there. At the same point as the LHS one but it points straight back. If the whole lot was shifted to the drivers side, it'd drop straight in on the standard hoses. But as standard, there is no room on these builds lmao.
I looked at an early polo rad, but I don't think it'd be quite big enough for the abuse this will be getting!.
