What Have You Done On Your Mini Today?
578 replies to this topic
#301 dickster
dickster
  • 107 posts
Posted 04 August 2009 - 09:14 PM
Picked up the Mini from the bodyshop-I can't belive how well its turned out.
#302 chappy
chappy
  • 1,253 posts
Posted 04 August 2009 - 09:18 PM
'billy' that sticker is amazing!!
#303 minivanman
minivanman
  • 3,454 posts
Posted 04 August 2009 - 09:25 PM
last 2 days - stripped old brakes, fitted new vented 4 pots, fitted minifins, replaced the rad, thermostat, headlamps, fan belt and replaced a few grease nipples with angled ones. And fitted work in around it somehow >_<
#304 Billy
Billy
  • 907 posts
Posted 04 August 2009 - 09:26 PM
I know Lol >_<
#305 sam_1275_carbon_sprite
  • 90 posts
  • Local Club: REKT AUTOMOTIVE
Posted 04 August 2009 - 09:28 PM
fitted halogen headlights, then the passenger sidelight bulb blew straight away, look at that tommorrow, fitted chrome grill and assembled spotlight bar, need to get some more wiring for the spots tho.
also received my dash from custom consoles.
#306 Asphalt
Asphalt
  • 2,173 posts
Posted 04 August 2009 - 09:36 PM
Took it for a drive :D New engine is fun... But need to get used to the MPH speedo skale (been constantly speeding >_< )
#307 Massey
Massey
  • 272 posts
  • Local Club: N/A (but looking for one)
Posted 04 August 2009 - 09:39 PM
took her to get some work done at wood and pickett :D should be a nice bill soon enough >_<
#308 Mr Joshua
Mr Joshua
  • 378 posts
  • Local Club: Rebels mini club
Posted 05 August 2009 - 01:59 PM
awesome cylinder head bertie passed mot with flying colours no advisories
Thanks shame I discovered a crack in it during the last phase of machining
#309 mintom
mintom
  • 216 posts
  • Local Club: TVMC
Posted 06 August 2009 - 11:17 PM
Wheel arch sprayed and fitted. New S/S front bumper fitted. One less dodgy looking bit!
New Door seals fitted. Hopefully the small leak into the driver footwell will begone forthwith..
Timing was out, measured it at 16degs, changed it to hover between 10 and 12degs, certainly better, but not sure how much of an improvement I'll see.. will find out on the drive to IMM tomorrow. If you see me with the bonnet up in a service station, hopefully I'm only fiddling with the mixture :D
Antenna connected properly so now have radio!
Random carpet thats been loose for ages, glued down and a wee spring clean in the cockpit :)
Best of all ... caught a rollover ... well it's the little things in life ...
Attached File  DSC01127_800.JPG   101.11K   10 downloadsAttached File  DSC01131_800.JPG   148.02K   15 downloads
Edited by mintom, 07 August 2009 - 07:04 AM.
#310 sam_1275_carbon_sprite
  • 90 posts
Posted 06 August 2009 - 11:34 PM
fitted my spots, and received my 3 clock dials XD spent about an hour gorming over the removal of the speedo cable, then another 2 gorming at the spot lamp wiring, then got my act together and wired it all up (the spots that is) and failed, shanty earthing methods and general half ars3d bodgery methinks :D anyway, got help with that so be sorted tomorrow, also going to fit dash, then if i have time, pack for my holiday (gotta set off at 8am on sat - don't know where anything is, don't really care, lenard needs his extra eyes XD)
#311 Figs122uk
Figs122uk
  • 823 posts
Posted 08 August 2009 - 03:37 PM
So far today, ive
Sprayed the Brake Calipers & Drums (the lazy way)
Went abit OTT on the first coat of paint. Hence the drip on the floor :thumbsup:
and installed a Fag Lighter
:thumbsup:
Want to wash it & t-cut it later >_<
Edited by Figs122uk, 08 August 2009 - 03:38 PM.
#312 Fire_monkey
Fire_monkey
  • 489 posts
Posted 08 August 2009 - 04:02 PM
decided to send mine back to the body shop to get some bit's touched up >_<
#313 Figs122uk
Figs122uk
  • 823 posts
Posted 08 August 2009 - 04:05 PM
Their Fault ?
#314 newdawn1st
newdawn1st
  • 1,268 posts
  • Local Club: Fylde Mini Club
Posted 08 August 2009 - 04:08 PM
Cursed my mini for breaking down last night, stall then missed then backfired spectacularly, then cursed myself after the breakdown came out and found all it was was the LT -ve lead had vibrated loose >_< 30 secs later and I was away. Was well worth the hour wait :sneaky:
Oh and the breakdown guy mentioned this was his 8th mini of the day, because of IMM, even one guy stuck in charnock richard with a primary seal failure, hence no oil, head gasket and a warped head, still turned over apparently too. A Series are nails :thumbsup: oh and the other broken mini was from Amsterdam :thumbsup:
Edited by newdawn1st, 08 August 2009 - 04:11 PM.
#315 carlnrtn
carlnrtn
  • 130 posts
Posted 08 August 2009 - 05:01 PM
I've spent hours trying to remove the rear subframe bolts which sheared off. Tried everything to get them off, still no luck!! Not good :/
