Knocking Sound Under Car When Going Over Bumps?
16 replies to this topic
#1 MINI 1
MINI 1
    The Ginger One #2
  • 714 posts
  • Local Club: LCMOC
Posted 08 July 2009 - 07:53 PM
as title says really , when going over bumpy road surfaces like pot holes ect , theirs a knocking , i have changed the shockers, and have made sure its not the exhaust . what could it be? had a check at work on the 4 poster ramp and couldent see anything loose ...
#2 sally the mini
sally the mini
  • 412 posts
Posted 08 July 2009 - 07:56 PM
depends on what you are running over fat people make a loud knocking noise wheras old people screech
#3 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 08 July 2009 - 07:58 PM
I would say mounts of some type - subframe, engine mount, engine steady, rod gear change mount... does the car knock when setting off quick from the lights etc? One quick test - handbrake hard on, grab hold of rocker cover and try shoving the engine back and forth while kneeling infront of the car, if movement can be seen, then suggests stabiliser bushes/engine mount. Perhaps the knock could even be heard by doing this. Otherwise, while on the ramp, trygently prying the subframe away from the body, if excessive movement here, then subframe mounts gone - dont forget the top tower mounts.
Ryan.
Edited by L400RAS, 08 July 2009 - 07:58 PM.
#4 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 08 July 2009 - 08:35 PM
check to see if your back seat is securely fitted, may sound stupid but there was an annoying knocking noise in my car
which turned out to be the back seat lol
#5 WoMaD
WoMaD
  • 140 posts
  • Local Club: Chichester Mini Club
Posted 08 July 2009 - 09:10 PM
i had a knocking when going over bumps... replaced the rebound buffers and it fixed it :gimme:
#6 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 08 July 2009 - 09:12 PM
radius arms worn, top arms worn, can be many things.
#7 The_Mistro
The_Mistro
    Farmer Barley Mow
  • 2,369 posts
Posted 08 July 2009 - 11:17 PM
brake dust shields???
#8 jaydee
jaydee
  • 8,565 posts
Posted 08 July 2009 - 11:25 PM
First check the rebound rubbers conditions. Worth replace them.
#9 Massey
Massey
  • 272 posts
  • Local Club: N/A (but looking for one)
Posted 08 July 2009 - 11:31 PM
ball joints, cv-joint?? check for play in the front wheels when its off the ground
#10 satvinder
satvinder
  • 557 posts
Posted 09 July 2009 - 12:18 AM
havnt got a bottle bouncing around off the box section under your seat. i spend days fixing my car took it for a drove n heard a nocking when going over a bump. i started to go mad and then finally found out it was a bottle i left in my car had gone under ,my seat!!!
#11 Pauly
Pauly
  • 4,213 posts
Posted 09 July 2009 - 08:30 AM
Loose drive flanges?
paul.
#12 wmkccwhite
wmkccwhite
  • 409 posts
Posted 09 July 2009 - 04:31 PM
Football in the boot?
#13 Pooky
Pooky
  • 5,691 posts
Posted 09 July 2009 - 05:16 PM
I'll second that!
Exhaust silencer box hitting seat belt stalk bolt under the tunnel? Although this is usually when accelerating and decelerating.
#14 jkjaxor
jkjaxor
  • 331 posts
Posted 09 July 2009 - 06:28 PM
if it is one single clonk, each time u speed up and slow down it will be some kind of engine steady or mount,
most likly the bottom subframe mount rubber sandwich has split and is letting the subframe pivot forward and back when changing speed. replace them with solid ones? some times there quite hard to tell if there gone as the spring back together and you cant see the cracks
#15 Stuboy
Stuboy
  • 26 posts
  • Local Club: PANDSMOC
Posted 10 July 2009 - 09:41 AM
i have a knocking sound in my mini... can only be heard when driving slowly though, i never heard it when out and about on the road, it's normally just when im reversing off the drive way onto the road... im sure it's coming from the back.
Where would i find the tower mounts? Im new to mini's so still finding my way around the car!
Stu
