Dismantled the rear hub assemblies now. Was a bit of a pain in the rear seperating the brake shoes and cylinders. Got the Radius arms back on the subframe. Thought I would do a little painting...
Keyed and Etch Primed four Hi-Los
Cleaned up and brush painted the rings on the rubber cones. Yes I do think these are ok to go back on. I have seen many other flat cones, and these don't seem too bad. I am saving up for fast road coil springs anyway..
Brush painted with Hammerite Silver. I do like the brushed alloy look of these
Also brushed on hammerite black. I know there isn't much point as they wont be seen, but I thought it was best to give them some protection.
I did do these lower arms ages ago, but I recently made a mess of them prising the old nylon cups out!
Painted up the rear backplates aswell. Not so sure aobut these. They look a bit rough.
I decided to also brush paint the inside floor and rear seat excluding the cross section. Just for protection of the panels. I just bought me a new HVLP spray gun Clicky
Should do me the job of spraying the rest of the inside and outside when the time comes. Should hopefully be purchasing some primer and thinners in the next week or so.
This is the other arch that wasnt done, is now done...
and a couple of other pictures I took of the underside.
Edited by Stupot_1982, 03 November 2014 - 03:38 PM.
