What Primers Can Be Used With 2 Pack
8 replies to this topic
#1 mini.cooper998
mini.cooper998
  • 685 posts
  • Local Club: looking
Posted 04 July 2009 - 05:10 PM
hi all bit of a nubie question im afraid.
used to spraying celly for a few years but have heard amazing things about 2k so going to give it a go. have big compressor force fed mask and a will to live
but want to know can i use 1k filler primer with 2k paint or does it need to be 2k primer
cheers folks
#2 kez_19
kez_19
  • 946 posts
Posted 04 July 2009 - 06:48 PM
i used 2k metallic red on top of 2k epoxy primer worked really well and epoxy even if its not the healthiest product out their it is tough as old boots
we use it at work to prime lorry frames when we rebuild them
michael
#3 Pauly
Pauly
  • 4,213 posts
Posted 04 July 2009 - 06:51 PM
I think the rules goes you can spray 2k over celly but not the other way around?
Paul.
#4 mini.cooper998
mini.cooper998
  • 685 posts
Posted 04 July 2009 - 07:45 PM
did think with it being an epoxy it would only take over epoxy
thanks for the help
#5 bndesigns
bndesigns
  • 21 posts
Posted 05 July 2009 - 09:24 PM
[quote name='Pauly' date='Jul 4 2009, 07:51 PM' post='1510199']
No that applies to synthetic, 2k will go over anything
#6 SolarB
SolarB
  • 1,385 posts
Posted 06 July 2009 - 06:39 PM
I wish! Had a bad reaction with 2k over an aerosol can from Halfords. :thumbsup:
#7 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 06 July 2009 - 06:46 PM
2 pack should go over any other type of paint...
Maybe you got some silicon between the halfords paint and the 2pack.
#8 Pauly
Pauly
  • 4,213 posts
Posted 06 July 2009 - 06:57 PM
2k will go over anything as said, but put celly etc over 2k it will react.
Paul.
#9 Frog
Frog
  • 492 posts
  • Local Club: Blakehill Mini's
Posted 06 July 2009 - 08:35 PM
cheers folks
Generally I stick to 2K high build primer with 2k top coat or basecoat depending on what you are spraying. 2K doesn't always go over anything I have had on several occasions had a reaction with 2k over rattle can primer. (Panels prepped by other people) All wiped down with panel with etc,etc. Have used barcoat in the past to stop it.
Generally 2k paint is great to use & can be applied a lot thicker than celly.
