Clunk When Accelerating/decelerating
9 replies to this topic
#1 Bill
Bill
    Just On Tickover
  • 7 posts
Posted 04 July 2009 - 12:55 PM
Model:Mini Sprite 1275cc SPi Manual
Year:1996
Whilst driving, if I lift off the accelerator (not touching the brake pedal) I get a clunk and if I hit the accelerator again I get the same clunk. It felt like the engine was moving forward or backward but I tried moving it with a pry bar (between the block and alternator) and there's no excessive play in the engine mounts or stabiliser bars.
I jacked the car up to get both front wheels off the ground.
Put the gearbox in reverse.
I can turn a wheel about 40 degrees before the other wheel spins.
If I turn a wheel back and forth I get the same clunk as the other wheel starts to turn (after about 40 degrees rotation either direction).
Is this normal?
Can you get 'play' in the diff or gearbox and still have a driveable car? :proud:
Thanks in advance
#2 minitomfoolery
minitomfoolery
  • 257 posts
Posted 04 July 2009 - 01:18 PM
Is your exhaust all secure?
#3 m1tch
m1tch
  • 1,044 posts
Posted 04 July 2009 - 01:37 PM
I know that some people have had issues where the manifold hit the rear bulkhead during acceleration and decelleration
#4 MRA
MRA
  • 7,607 posts
Posted 04 July 2009 - 03:04 PM
It could be top engine mount to bulkhead bracket or if you are lucky then its just bushes.....
However the wheel turning 40 degrees, keep a watchful eye on this one, if it gets worse then its a diff pin or better still fit a cross pin diff, if your diff pin fails it WILL destroy your grarbox, and if you are really lucky that's all it will do................ it can in extreme cases cause severe loss of control and cause a major RTA :proud:
Regards Martin
#5 mini_mentalist_chris
  • 137 posts
  • Local Club: S.L.M.O.C.
Posted 04 July 2009 - 03:52 PM
Things to check:
1/ Top engine steady bar bushes (definately) and bracket.
2/ Engine mounts.
3/ Subframe mounts
4/ Make sure exhaust is secure.
Other possibilities include pot joints. worn diff, worn gearbox, worn drop gears. Could also be the clutch (disintegration of the torque springs)??
Hope this helps
Chris
#6 m1n1
m1n1
  • 755 posts
  • Local Club: I'm unsociable
Posted 04 July 2009 - 05:40 PM
in my experience its always been the top subframe mounts. replace that and see how you get on..
#7 Pauly
Pauly
  • 4,213 posts
Posted 04 July 2009 - 06:49 PM
Alot of people forget the tower mounts and this is what caused my problem with the subby moving.
Paul.
#8 Bill
Bill
    Just On Tickover
  • 7 posts
Posted 04 July 2009 - 07:58 PM
Thanks for all the responses!! Much appreciated.
The car was only MOT'd last week and so I'd hope any dodgy subframe mounts etc. would have been picked up by the tester.
I might take it back to the garage and have him check it out.
Thanks again
#9 westpark15
westpark15
  • 133 posts
  • Local Club: mini drivers club
Posted 04 July 2009 - 08:30 PM
hey
i had exacly the same problem
and it was the top engine mount on the left hand side :D
glad i could help you with this one :D:D:D
nigel
#10 91neon
91neon
  • 447 posts
  • Local Club: abingdon owners club
Posted 04 July 2009 - 09:31 PM
i know you say youve checked but mine sounded identical i had about one cm play on top left engine steady and it caused enough mvmnt for exhaust to hit
