As you can see from the pics hes just needing a little TLC as the common rust areas are well and truely eating away.
1st job was to run the car to the MOT station to find out how bad Austin was,
list of problems as follows
1. Exhaust has a major leak
2. Exhaust emissions exessively high
3. OSF incorrect indicator colour
4. Fuel Pipe Leaking
5. OSR fog lamp not working
6. OSF CV joint gaitor split
7. NSF CV joint gaitor split
8. NSF wheel bearing has excessive play
9. OSF wheel bearing has excessive play
10. NS windscreen washer provides insufficiant washer liquid
11. NSF front tyre below tread depth requirement
well in all honesty thas nothing bad at all, considering Austin has been laid up since the last MOT in 2004.
my Dad has been well on the case this week and credit to this legend and all the bits have been fixed, replaced or adjusted where required (exept bald tyre) all in record breaking time and to the highest possible standard.
Ive just ordered a couple of little bits for the outside work to start, namely teh sportpack arch kit and front clear lenses. Hoping to get some nice 7x13 Ultralite wheels on soon along with 4x driving lamps and a full RollCage. :thumbs:
Next week will bring some new body panels and then the work really begins bringing Austin to a good standard.
There is still alot to do but here are a coupel of pics from when I trailered him back 300 odd miles.
comments from the MOT man were warming too, as the underside is pretty dam solid, which is always a fear on these cars.
Edited by KEV@POWARTEK, 03 July 2009 - 03:03 PM.
