Sound Proofing
8 replies to this topic
#1 finch661
finch661
  • 2,339 posts
Posted 01 July 2009 - 09:55 AM
i am looking at putting some sound insulation on the interior side of the firewall to reduce the engine noise (wich is very loud). i will be fitting a centre speedo so i will have the dash and bits out anyway, so i though i might as well put some insulation in. i already have the felt stuff on the engine side of the firewall, but it didnt do much!.
this stuff looks quite good,
Ebay linky
let me know what you think?
oh they also do some form of sound deadening paint.... any good?
other linky
just realised that this was going in the ice section...whoops
Edited by finch661, 01 July 2009 - 10:55 AM.
#2 jaydee
jaydee
  • 8,565 posts
Posted 01 July 2009 - 12:24 PM
Dynamat is ok, but probably halfords is cheaper.
I wouldnt use the bitumen sound deadening paint, not worth at all.
Its like the soundproof goop you have on the floors, weights a lot and isnt so good for sound insulation..
#3 finch661
finch661
  • 2,339 posts
Posted 01 July 2009 - 01:06 PM
cool, i found the halfords stuff (Vibe Sound deadening) , is it any good though?
#4 mini_mentalist_chris
  • 137 posts
  • Local Club: S.L.M.O.C.
Posted 01 July 2009 - 01:59 PM
I've just had a look at the halfords one as I want to mat my car too. It is more expensive than the stuff you found on ebay! A 32"x18" piece is £24.99 as opposed to the 10' by 12" roll on ebay for £17.95 (+p&p).
I would have thought they would be fairly similar. I definately won't be using the paint on stuff. The matting is much better.
#5 Fire_monkey
Fire_monkey
  • 489 posts
Posted 01 July 2009 - 05:51 PM
sorry to hijack your thread but..
how much sound insulation would be needed for the floor of a mini saloon?
#6 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 01 July 2009 - 08:29 PM
Have a read of this thread a very good guide!
http://www.theminifo...showtopic=81314
Personally i would avoid the sludge as somewhere along the line you are only gonna have spend days hacking it away again!
#7 WelshMiniNut
WelshMiniNut
  • 65 posts
  • Local Club: Snowdon Minis
Posted 03 July 2009 - 10:59 AM
Pop down to your local builders merchant and get some flash band,usualy comes in rolls!Much cheaper than dynamat etc,and is basicaly the same stuff.Ive seen it used and its brilliant.
#8 finch661
finch661
  • 2,339 posts
Posted 03 July 2009 - 01:00 PM
sounds good, as long as it blocks out the noise of my engine :D
#9 WelshMiniNut
WelshMiniNut
  • 65 posts
Posted 03 July 2009 - 05:03 PM
Ya shud do mate.one of the guys who run the local club used it,when u knock the shell it sounds absolutely sollid compared to an ordinary one!lolI would say use the flash band on the inside right up the toe boards and get the original sound proofing mat for the bulkhead under the bonnet,good luck
