Don't quite understand what this means. 20 what and 40 whatmini has done 97,000 but is in excellent condition.
head been skimmed and new gasket fitted. i have had the car since 60,000 miles (4 years)
spoke to Rover today and they have now found a fault on the ecu, too much vacum going through should be 20 but trying to run at 40. they are trying to find out if they can bypass it.
The ECU MAP sensor reads the manifold vacuum, at idle the sensor should read something like 550 millibar. If at idle it reads 200mbar then there is either an air leak, fuel in the map sensor liquid locking it( See previous post) or the MAP sensor is goosed and unfortunetly a new ECU.
