i've got to say, after all the trouble i had with mine i'm glad i changed it all back to the carb set up...
Sorry mini sprocket, i was grateful for all the help you gave at the time, but what a nightmare...
No worries dude :cool: . The bloke I got the injection manifold off removed the injection manifold and fitted twin carbs, he retained the ecu for the alarm/ imobiliser and the ignition. This was because the engine was heavily tuned to the point where the injector ran out of squirt and melted the pistons :saywhat: . The twin point system was a quick fix that did nothing to improove the system over all, so the engine could pass emissions standards. ( i believe none of the mighty minis use the twin point system because its worse than the single point system))So fitting carbs does happen and it works, as you well know. :cheese:
Very interesting bloke he was too. To try and overcome the lack of squirt, he modified a standard manifold to take two SPI throttles/ injectors and linkaged them together, the only problem was the MEMS ECU could not carry the extra juice of the extra injector and he scrapped the idea. The guy hadn't heard of the Megasquirt system, so pointed him in the right direction. Expect a twin single point injection system
showing its face in the mags in the near future
He worked for the then Rover and has a garage full of gear
No surprise.
