Banding Steel Wheels.
Posted 26 June 2009 - 01:22 PM
wondering where you guys send your steel wheels to get banded.
cheers
Posted 26 June 2009 - 01:26 PM
http://retrorides.pr...s.com/index.cgi
Posted 26 June 2009 - 01:29 PM
Wheel banding Hmmmmmm,hi all.
cheers
Dont quote me but I believe that banded wheels are actually not road legal. They are fine for competition use but for a road car a no.no.
Posted 26 June 2009 - 01:30 PM
Posted 26 June 2009 - 02:59 PM
http://www.wide-wheels.co.uk/
Never had any done there so can't comment on the quality but have been tempted!
Posted 26 June 2009 - 03:05 PM
Posted 26 June 2009 - 03:14 PM
They are not
This is a Reply Direct form VOSA - having been given the exact details of Banded Steels:
There are no specific regulations in the Road Vehicles (Construction and Use) Regulations 1986, as amended (C&U) relating to the type of work you propose.
Regulation 100 of C&U does require that all parts fitted to a vehicle are not likely to cause a danger to the user of the vehicle or other road users. I have attached a copy of Regulation 100.
Additionally, you will need to ensure that the wheels do not protrude from the wheel arches, or that modifications are made to the bodywork of the vehicle to ensure that the wheels do not protrude.
Yours sincerely
*name removed*
DfT - Transport Technology and Standards
So, Just like you can fail an MOT on incorrect/shoddy welding to structural/load bearing areas on your mini - The same is applicable on wheels as they are obviously load bearing.
So if they've been made incorrectly - bodged together and are downright dangerous - They will fail you an MOT (and god forbid should you decide to fit them regardless), If they've been made correctly there is no problem.
WideWheels make them properly.... If you buy them 2nd hand - take them to a professional for their opinion on the construction before fitting.
Posted 26 June 2009 - 04:53 PM
there not a 10" wheel there a 15".i know what your thinking ----they wont fit on a mini
your correct they wont,they are for a nissan 200sx.
i thought this would be a good place to ask as you guys do like wide wheels.
thanks.
retro 10's is correct they are not illegal if done to a high standard.
all steel wheels are welded at the end of the day.
Posted 26 June 2009 - 05:32 PM
If only - Original Mini steel wheels were Held together using about 4 Big Old Rivets inserted hot,... if I remember correctly (or were they huge plug welds?)
Posted 27 June 2009 - 05:51 PM
the answer is in your post,
plug welds.
