Reverse Light Switch Wires
3 replies to this topic
#1 mrbridger
mrbridger
  • 422 posts
  • Local Club: no
Posted 24 June 2009 - 06:48 PM
1980 mini 1000. Centre speedo.
My reverse lights do not work. i decided to replace the reverse light switch.(Frankly impossible to replace via the underside if you have an exhaust fitted)
I replaced this eventually by accessing the housing by removing the gearstick gaiter and the other bits covering the aperture.
This didn't solve the problem. Some prodding around with a 12v tester revealed power at the new switch. I then discovered that one of the two wires which travel up behind the heater had been cut. (there is a green wire and a green/red wire) ...its the green/red wire which is severed and no amount of feeling around behind the heater and examination with a lamp has exposed the other half.
can someone help with the tracing of this wire?
I assume it extends up through the bulkhead to within some part of the loom behind the centre speedo and maybe linked to the fusebox somewhere.
Andy
#2 Nightrain
Nightrain
  • 976 posts
Posted 25 June 2009 - 03:29 PM
Green wire is the live from the fusebox as you've found and the green/red (actually green/brown) goes to the rear lights. So if you don't fancy ripping out the speedo etc, you could just run a extra wire to the lights.
#3 mrbridger
mrbridger
  • 422 posts
  • Local Club: no
Posted 25 June 2009 - 08:25 PM
Would it require a connection of the green/brown wire to both reverse lamps?(integral reverse lamps in the cluster)
#4 Nightrain
Nightrain
  • 976 posts
Posted 25 June 2009 - 11:17 PM
Yes if your gonna run it straight to the lights, you could even if your not to bothered about appearance just scotch lock it onto the green/brown wire from the light itself and then over to the other reversing light. Not pretty but would be fine.
